Euro Headlight Installation
Old Oct 22, 2005 | 11:38 AM
DeeGee's Avatar
DeeGee
Default Euro Headlight Installation
Just installed my Euro Headlights.
Installed the right hand unit last night and the bolts that hold it into the cage are a real PITA. Decided to leave the left hand one until this morning so that I'd be fresh.
Afetr I'd hooked up the bulbs I sat the headlight on the fender and reconnected the battery to check that all the lights were working before I reinstalled it.
You've guessed it.......the vibration from the headlamp motor dislodged the light and I watched it drop in slow motion to the floor. Cracked the lens.
Went onto GM Direct to order a new one and punched in the wrong part number. The orders confirmed for the wrong light and they have no number to call to amend the order. It has to be done by E Mail. I'm now on tenterhooks. If I cant change the order I have 2 right hand lamps and a broken left hand lamp.
The only good news is that all the lamps are working but the cracked lens looks like ****
Some days life just sucks.
Old Oct 22, 2005 | 12:21 PM
ErnieN85's Avatar
ErnieN85
Darn thats nasty, I had the euro headlights on my 85 the lens seemed the same for both sides! take a closer look two rights may work fine if all you need is the lens.
BTW you can get the housings (lens & reflector) at most autoparts stores a Euro lamp for a motorcycle I got hellas for my C4 and they just replaced the one piece bulb & lens assembly
Old Oct 22, 2005 | 12:55 PM
Freestyler's Avatar
Freestyler
Mate...
thats aweful
im sure they will let you change it, it is USA afterall capital of TakeItBackAnywhere
bcseitz's Avatar
bcseitz
Bummer. I could picture myself doing that too!
Post pics when you get it finished....
Old Oct 22, 2005 | 12:59 PM
DeeGee's Avatar
DeeGee
Sadly they're different. Theres 2 holes for the bolts on one side and one on the other. They're different for each lamp.
Ho hum
Old Oct 22, 2005 | 01:07 PM
DeeGee's Avatar
DeeGee
Here's a good looking Euro headlight:
And here's one with a great big crack across the lens
Old Oct 22, 2005 | 07:21 PM
b98's Avatar
b98
That just CRACKS me up.
Old Oct 22, 2005 | 11:35 PM
edensknight's Avatar
edensknight
Hang in there.
Old Oct 22, 2005 | 11:43 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Best of luck getting things resolved.
Old Oct 23, 2005 | 05:16 AM
FiberglassFan's Avatar
FiberglassFan
The C5 headlights are very different left to right. One nice thing about the earlier generations was the easy fitment of Cibie or Hella euro lighting...not so with the C5.
I got my T-84s at www.cibieusa.com at considerable savings compared to local chev dealer, even with our club discount, which can be substancial. The fellow there drives a C5. He gets the T84s in Europe to bypass all the profits taken by regular GM distrubition taking them into the US.
Huge improvement in lighting, you'll see soon!
Old Oct 23, 2005 | 08:32 AM
Dark-Knight's Avatar
Dark-Knight
Ouch! That does suck!
Old Oct 23, 2005 | 09:10 AM
DeeGee's Avatar
DeeGee
I had a dream last night.
A Euro headlight kept jumping to the floor and commiting suicide
Nasty stuff
Old Oct 25, 2005 | 08:39 AM
DeeGee's Avatar
DeeGee
Default Great Customer Service
Have to say the after my error GM Parts Direct were outstanding.
Had 2 E Mails yesterday by 9AM cancelling my order. Reordered lastnight.
Well done to GMPD.
Old Oct 25, 2005 | 08:58 AM
ErnieN85's Avatar
ErnieN85
Well done to GMPD.
That is great to hear I always wondered what would happen
Old Oct 25, 2005 | 12:12 PM
Mad_Maxxx's Avatar
Mad_Maxxx
Sorry to hear about that buddy, I just got done installing my T84's and almost did the same thing. Because I wanted to avoid the same fate as yours, I made sure to put on the one "easy" bolt on the left side(left light) on before reconnecting the battery(you did disconnect the battery, right??!!). Good luck to you
[IMG][/IMG]
Old Oct 25, 2005 | 08:01 PM
DeeGee's Avatar
DeeGee
[IMG][/IMG]
I had the battery on and off so many times that I lost count.
You have no idea how careful I was for the rest of the installation. Just one fatal error.
Oh well $85 later and I'll have corrected the **** eyed look
To Euro Headlight Installation
