I do not believe the corrosion warranty covers wheels. The dealer might (and I use the term lightly) cover the wheels if it is still under the 3 yr/36K warranty.
Does the GM corrosion warranty cover wheels also?
My wheels on my 2002 show signs of corrosion... peeling the clear coat... is this still under warranty?
(ps. I didn't get the manuals with my car when I bought it)
thanksDenis
It was on our 92' RS Camaro............
Ask and you can recieve
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Is peeling clear coat really considered corrosion? I'd bet the General will not cover it - they will tell you that the clear coat was cleaned improperly. It's worth a shot, the worst they can say is NO and then you're no worse off than you are right now. Ask your "friendly" local Chevrolet dealer, you might stand a slim chance if the car is still under the 3/36, like JD said above, but don't get your hopes up too high for a replacement wheel on a 4 year old car......
