Glue Problems
Old Oct 24, 2005 | 11:57 AM
GeorgieMporgie's Avatar
GeorgieMporgie
Default Glue Problems
I just purchased a 99 Coupe and the previous owner had a radar detector attached to the dash. Now that the detector is gone all that's left is the glue from the two sided tape he probably used to hold it on the dash.
Question: How do I get the glue off without damaging the dash.
Secondly, the previous owner also installed the Corvette letters on the rear fascia and I would also like to remove these along with the glue underneath them.
Questions how do I get the glue off the fascia without damaging it.
Any help would be appreciated.
By the way I love my new Vette. My first and man is it great. I've wanted a Corvette since I was 16 and finally got one Saturday. Pics to be posted at a later time.
Old Oct 24, 2005 | 12:09 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Congratulations on the new Vette. Welcome to the forum.
I believe that you can use Goo Gone for the dash pad to remove the adhesive, I'm not sure as I've never done it, but I believe it will be safe....someone else with experience can verify for me. On the rear letters, try heating them with a hair-dryer and just prying the letters off. You should be able to use denatured alcohol to remove the balance of the adhesive.
Paul
Old Oct 24, 2005 | 12:10 PM
jrose7004's Avatar
jrose7004
Goof Off on both! Congrats on the Vette!
Old Oct 24, 2005 | 01:36 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Like said above, goo be gone, works awesome, and it is all natural, Oranges
Old Oct 24, 2005 | 01:39 PM
WNeal's Avatar
WNeal
Cruise-In Veteran VII
Cruise-In Veteran VIII
"Slower Azz Dog"
Goo Gone, but make sure to treat the area with some kind of leather treatment etc. when finished so you don't dry it out.
Old Oct 24, 2005 | 04:25 PM
RocketJ's Avatar
RocketJ
Goo Gone is the stuff, I've used it on many different surfaces with never any damage.
I would get some modeling clay and build a small dam around the area, then soak it good and go grab a beer. The longer you let it sit the better.
RocketJ
Old Oct 24, 2005 | 04:29 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
heat it first w/ hair dryer, this gets the adhesive off in one shot, if that doesn't work use the other stuff mentioned, congrats on rem'g the goofy 'corvette' letters, now YOU will be the one that stands out w/ the factory look
Old Oct 24, 2005 | 06:02 PM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
Paul
Goo Gone on the dash and the dryer will soften the adhesive on the letters to get them loose enough to remove, then the Goo Gone will remove the remaining adhesive. In fact this is what the vendor recommended when I purchased my inserts if I needed to re-position them or remove them. Good Luck and enjoy! Zuti
Old Oct 24, 2005 | 06:12 PM
MYRagtop's Avatar
MYRagtop
Goo Gone
Old Oct 24, 2005 | 06:15 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Good stuff.
Old Oct 24, 2005 | 08:20 PM
GeorgieMporgie
I just used the hair dryer on the letters in the back and they came off clean. Thanks for the tip.
I'll try the hair dryer on the dash too to see if that takes the adhesive off. If not I'll try the Goo Gone, but before I do has anyone actually tried this on the dash? The last thing I want to do is DAMAGE THE DASH.
Old Oct 24, 2005 | 09:02 PM
edensknight's Avatar
edensknight
You have definitely received the best advice regarding what adhesive remover to use (i.e., "Goo Be Gone"). But, again, I cannot stress to you enough on how a simple hand held hair dryer is your best friend in such matters. My custom detailer uses a stronger variant (an actual heat gun) held up close to the product and area needing treatment (letter and decal removal, body side moulding removal, etc.). And, a common hair dryer works great. Just take your time with this project. And, you should be able to achieve the results you are looking for. Good luck to you.
Old Oct 24, 2005 | 09:13 PM
C5Jim's Avatar
C5Jim
I use 3M Wax and Adhesive Remover. It is extremely effective and safe for the dash. Bear in mind it will take off any protectant (i.e Armor All) that you had on the dash, but that's an easy fix.
Also, you could try rubbing alcohol. It too is safe and effective albeit a little slower.
Good luck.
Old Oct 24, 2005 | 09:45 PM
rkerr1234's Avatar
rkerr1234
IPA
Old Oct 28, 2005 | 01:18 PM
GeorgieMporgie
I just tried the hair dryer on the dash adhesive and this stuff didn't even soften a bit. I'll try either the goo off or 3M product and see what happens. Why would someone use something so potent on the dash. What $%@$#@% goof.
Old Oct 28, 2005 | 03:24 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I would try the hair dryer before using the alcohol.
Old Oct 28, 2005 | 04:27 PM
rws.1's Avatar
rws.1
IPA ? Isn't that a beer? ... India Pale Ale
ohhh... you must mean Iso Propyl Alcohol available from your local
Pharmacy
Old Oct 28, 2005 | 05:39 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Goo is you're friend
Old Oct 28, 2005 | 06:19 PM
LoneStarFRC's Avatar
LoneStarFRC
Maybe the previous "owner" was leasing and didn't give a rats rectum. Good luck.
To Glue Problems
