C5 Vert Leak Problems?
Old Oct 24, 2005 | 01:03 PM
Hammie's Avatar
Hammie
Default C5 Vert Leak Problems?
Hey guys, almost had my car chosen until I found a vert that I like. I don't see how this couldn't be a repost but after searching for half an hour I couldn't come up with enough anecdotal evidence. I heard that during the c5 era, the vert leaking problem/wind noise was fixed. I am looking at a 2000 vert with low miles.
Do any of you vert guys have problems with the window sealing (i.e. leaking/wind noise) The car will be garaged but it WILL be washed a lot and may get caught in the rain. Just interested if all of you vert guys have leaky verts during washes, etc.
Old Oct 24, 2005 | 01:08 PM
LV_2_XLR8's Avatar
LV_2_XLR8
No probs here. My wife's Vert is three years old and has never leaked.
Old Oct 24, 2005 | 01:17 PM
aaavette's Avatar
aaavette
I haven't had any problems with my '03. If I direct the hose right at the door window seal, I do get a few drops on the inside of the glass. It is very few, and never any problem in the rain, at least the very few times I have been caught out.
Old Oct 24, 2005 | 01:33 PM
vectorz's Avatar
vectorz
I do on my 98. One of the seals on the top passenger door window area came off. Also, I hear wind noise here and there.
Old Oct 24, 2005 | 01:36 PM
dunbindun(tov)'s Avatar
dunbindun(tov)
Bought 02 vert used in June; drove 150 miles home in rain w/o problems then or since. It's not my daily driver, but I'm not afraid to get it wet/dirty.
The forum consensus appears that routine care with RaggTop will keep it in good shape.
DBD
Old Oct 24, 2005 | 01:44 PM
smooth1's Avatar
smooth1
Those rubber seals on the convertible top can be ajusted outwards so as to form a tighter fit with the window. Or you can buy new seals and fit them properly. Also, the window can also be 'tilted' inwards a bit if necessary. You get in from the bottom of the door. Then you should be nice and dry inside.
acecpa's Avatar
acecpa
No problems with my 98 vert.
39k miles on it.
Old Oct 24, 2005 | 01:52 PM
YCIS's Avatar
YCIS
High pressure car washes are a nono
Old Oct 24, 2005 | 02:08 PM
WKMCD's Avatar
WKMCD
39k miles on it.
Same here!
Old Oct 24, 2005 | 02:21 PM
Roc87's Avatar
Roc87
My vert leaks on the drivers side in a downpour. Also can hear some wind noise @ 80. Passenger side seals great, no noise or water. Haven't tried adjusting anything yet as it rains less than 9in a year here.
Forgot to mention, car has 36k miles, and top looks new.
Old Oct 24, 2005 | 02:46 PM
Cole's Avatar
Cole
I have a 2000 Vert and it doesn't leak. 35K miles. Never been adjusted. Car is like new - including the top.
Old Oct 24, 2005 | 02:51 PM
On the road's Avatar
On the road
I have never had a problem with my top leaking.
Old Oct 24, 2005 | 03:16 PM
Hammie's Avatar
Hammie
Great info, thanks all
Old Oct 24, 2005 | 03:25 PM
hrcantrell's Avatar
hrcantrell
Default No leaks
04 vert, no problems with water or air. Harold
Old Oct 24, 2005 | 03:28 PM
gotnovette's Avatar
gotnovette
No problems here except for the door jambs getting soaked when I wash the car
Old Oct 24, 2005 | 03:29 PM
Greg Gore's Avatar
Greg Gore
Default C5 Convertible Water Leaks
I have a 2004 with 1800 miles and when I wash and rinse it with normal water spray from the hose nozzle a small amount will get on the seat bolsters both sides. I just place folded towels on both sides to catch the water that gets by the seals and its not really a problem. I have not been in the rain yet so don't know how it would fare then but I assume what I have seen so far is because of the pressurized rinse.
Regards, Greg
Old Oct 24, 2005 | 03:35 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
No issues ('99 and "04) - except if - gasp - you go through a car wash. Expect some then (at least that is what I hear
To C5 Vert Leak Problems?
Old Oct 24, 2005 | 04:52 PM
oaks99's Avatar
oaks99
no problem with mine as far as water goes but you might want to consider a partition to seperate cabim from trunk .
Old Oct 24, 2005 | 05:01 PM
Hammie's Avatar
Hammie
Why? Isnt the tonneau cover down when the top is up anyway? Please explain, thanks!
Old Oct 24, 2005 | 05:03 PM
ayeroff's Avatar
ayeroff
The top on my 2000 vert still seals just as tight as ever. No leaks. No wind noise.
Funny thing is that my previous 1999 Coupe had really bad wind-noise and some leaking on the passenger side of the targa top. So when I bought the vert, I was expecting even worse. Quite a pleasant surprise.
