Ghost
Old Oct 25, 2005 | 11:58 PM
1STDROP123's Avatar
1STDROP123
Default Ghost
WENT OUT TO GET IN MY CAR AFTER WORK AND MY CLOCK WAS AT 1:00 AND IT WAS 6:30 SOUNDS SILLY I KNOW BUT I DID NOT CHANGE IT ANY IDEAS SERIOUSLY . ALSO FOR THE FIRST TIME MY LOW COOLANT READING CAME ON NEVER BEFORE OR SINCE . ARE THESE JUST NORMAL OR IS THERE SOMTHING UP WITH THE COMPUTER ON BOARD TO FIX? ANYONE ?
Old Oct 26, 2005 | 12:08 AM
Bounty Hunter 6's Avatar
Bounty Hunter 6
Check your battery for leaks....it sits right over your computer, so gravity can be a PITA. If it was at 1:00, chances are your car "reset" itself an hour prior to that (they usually reset to 12:00 I believe). There have been some people that have "electronic gremlins" on here, so I'm sure you'll get some good responses. Another culprit is grounding, but I'll let the experts talk about that....they'll be here soon!!
Old Oct 26, 2005 | 12:09 AM
DeeGee's Avatar
DeeGee
Is it the original battery on yor 99?
Old Oct 26, 2005 | 12:17 AM
GrayC5's Avatar
GrayC5
PERHAPS A BATTERY ISSUE. NOW CAN WE TURN OUR CAPS LOCKS OFF AND QUIT YELLING AT EACH OTHER?
Good luck.
Old Oct 26, 2005 | 12:42 AM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Old Oct 26, 2005 | 01:32 AM
1STDROP123's Avatar
1STDROP123
Default Ghost
IT IS MY ORIGINAL BATTERY BUT ALL WORKS WELL OTHERWISE DO I NEED A NEW ONE IF SO WHAT IS THE BEST
Old Oct 26, 2005 | 02:07 AM
TruUndrtkr's Avatar
TruUndrtkr
Old Oct 26, 2005 | 02:54 AM
Target Chaser's Avatar
Target Chaser
From: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
Originally Posted by TruUndrtkr
Old Oct 26, 2005 | 02:57 AM
TruUndrtkr's Avatar
TruUndrtkr
Originally Posted by Target Chaser
You ruined my ghost post..
Old Oct 26, 2005 | 03:14 AM
lickitydoo's Avatar
lickitydoo
spooky.
Old Oct 26, 2005 | 03:25 AM
Scott04Z's Avatar
Scott04Z
From: I'm not quite middle aged and I only own one gold chain! San Jose CA
Definitely get your battery tested...you are long overdue for the ever popular battery failure that the Delco batteries are so well known for. More than one forum member has switched out their stock batteries after a year or two simply because they fail so frequently.
Optima seems to be the most popular replacement.
Old Oct 26, 2005 | 06:11 AM
Dark-Knight's Avatar
Dark-Knight
Not ghosts, gremlins! And yep, probably need to get the battery tested as a starting point...
Good luck!
Old Oct 26, 2005 | 01:08 PM
Sure could be a battery problem. Have the system checked and if you need a new battery, the Optima Red Top is a good choice.
Old Oct 26, 2005 | 04:03 PM
edensknight's Avatar
edensknight
Originally Posted by lickitydoo
spooky.
Old Oct 26, 2005 | 04:25 PM
MikeNMaxZO6's Avatar
MikeNMaxZO6
I thnk you've got GHOST's in your car!
Old Oct 26, 2005 | 04:50 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Casper says -"Check your battery my friend, sounds like it's given up the ghost!"
Old Oct 26, 2005 | 05:08 PM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
Yes...weird things happen when the battery starts to go. Odd DIC messages, strange seat/memory settings, hearing voices....
Have it checked at your local advance auto or autozone...bought an optima red top last month for $100.
Old Oct 26, 2005 | 05:34 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Please - no more yelling - use the shift key.
If you have the original battery - run, don't walk, to the nearest Auto store and buy a new one.
Remove your existing battery, and look for any acid leak/residue on the bottom of the battery or the tray.
If there is any - get some Arm/hammer and douse the area completely.
Wash it off.
Replace battery.
Cross fingers and hope that the acid hasn't got to the electronics.
BYW - read the forum more ofter - this matter has been posted a gazillion times.
Old Oct 26, 2005 | 05:54 PM
rws.1's Avatar
rws.1
buy a spiral cell gel mat type battery... They are designed not to leak.
That is the technology used in Optima and in The Exide Orbital.
To Ghost
