wheels 1" wider
Old Oct 26, 2005 | 08:52 AM
PHPD7102's Avatar
PHPD7102
St. Jude Donor '14-'15-'16
Originally Posted by WKMCD
I run 1 inch wider front and rear wheels but 18's all around. I run Kuhmo MX's 275x35 and 295x35. I think if you go over 295 on the rear your going to run into a tire that protrudes from the wheel well. OK if you like that look, I don't.
I have 18x11 in the back and have a little prtrusion heres a pic to give you an idea.
b98's Avatar
b98
just do it. it works.
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
Originally Posted by 97Rob
Stuarts car "the pictures posted in this thred" are 305. Is this the same deminsion you are talking about? His don't seem to pertrude past fender wells. I may not mind that anyway, just as long as it dosn't rub.
thanks for input
97Rob
no rubbing...and StuzVette is lowered on stock bolts...
...and actually toward the line of the fender just follows the line of the tire at the top so you dont get the impression that the tires are sticking out at all...
...and just so you know...handling is not an issue...
with or without active handling on....
Old Oct 26, 2005 | 08:59 AM
427Z's Avatar
427Z
I like safer, the original idea was the look of the set up.What is under steer?
Thanks for all the help.
97Rob
if you go too fast in a turn, if your car is under steering, then you will loose front grip before the rear breaks loose.
its safer because the average driver can better handle the car if the front looses traction in a turn as opposed to the rear sliding out from under them.
on the roadcorse, you would need a bigger front
Old Oct 26, 2005 | 01:06 PM
I had 17x9.5 and 18x10.5 Z06 wheels on mine and had no problems. Had stock Z06 size tires on them and they fit inside the fenders just perfect.
Old Oct 26, 2005 | 01:10 PM
shurite44's Avatar
shurite44
I ran 315's on 18 x 10.5's (rear)and 285's on 18 x 9.5's (front) handled nice on the street I never ran it on a track. 285's were flush and the 315's stuck out a little, less than a 1/4 inch I think.
Old Oct 26, 2005 | 01:15 PM
shurite44's Avatar
shurite44
I think the Z06 wheels are a perfect fit for a C5 on the street. Plus you can run them on stock C5 size wheels. Just a thought for you, that is how I am going next time around.
Old Oct 26, 2005 | 01:47 PM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
go 315/35/18. it'll look much nicer!
Aj
Old Oct 26, 2005 | 01:52 PM
427Z's Avatar
427Z
Aj
the only tire they make in that size is a kumho racing slick
Old Oct 26, 2005 | 04:53 PM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
BFG makes a drag radial in that size..or was it 315/30/18..i know its one of the two... thats what i plan on getting. currently have nitto 555R 305-35-18 on my Z06 repros 18x10.5
Aj
Old Oct 27, 2005 | 06:22 AM
97Rob's Avatar
97Rob
Aj
Will you also use this tire for primary street driving?
Rob
