wheels 1" wider
Old Oct 26, 2005 | 06:12 AM
97Rob's Avatar
97Rob
Default wheels 1" wider
Is there a down side to having 17x9.5 front 18x10.5 back.
Will be ordering ZO6 repos soon, and lowering the car. Also putting widest drag radial on back. Wonder about clearance.
Will this tire work?
nitto 305-35-18 back
nitto 275-40-17
I think the meatier tire may look better,at least on the back. Maybe I should stay with 8.5" wheel on front. Want the best look and performance.
Pics would be nice.
Thank you for yor time.
97Rob
Old Oct 26, 2005 | 06:35 AM
ls1vette97's Avatar
ls1vette97
I'm thinking of the same tire's myself, should be no problem!
Old Oct 26, 2005 | 06:50 AM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
I like wider tires too...
StuzVette is 18 X 9.5 front and 18 X 10.5 rear...
Nitto 285 35 18 front and Nitto 305 35 18 rear...
Here are some pics so you can see how they fit...
...Im glad I did go with the larger tires and 18's all around...
Old Oct 26, 2005 | 06:52 AM
WKMCD's Avatar
WKMCD
I run 1 inch wider front and rear wheels but 18's all around. I run Kuhmo MX's 275x35 and 295x35. I think if you go over 295 on the rear your going to run into a tire that protrudes from the wheel well. OK if you like that look, I don't.
Old Oct 26, 2005 | 07:44 AM
427Z's Avatar
427Z
it just depends on the offset of the wheels. there is room enough back there for a nicely tucked in 305 tire on a 10.5 or 11" wheel. you just need to have about 8.5-8.75" back space.
the Z06 wheel only has an 8" back space so its going to stick out 1/2" more than a max backspace wheel.
even then, its an aggressive offset. i dont think it actually sticks out. but still, if aggressive isnt your taste, i understand
btw, i have done the 18/18 wheel combo twice with ccw and motorsports. i think it totally throws off the cars proportions. both times i wished the rear could be an inch larger to make the car look more aesthetically pleasing. jmo
Old Oct 26, 2005 | 08:15 AM
97Rob's Avatar
97Rob
I run 1 inch wider front and rear wheels but 18's all around. I run tsmo MX's 275x35 and 295x35. I think if you go over 295 on the rear your going to run into a tire that protrudes from the wheel well. OK if you like that look, I don't.
Stuarts car "the pictures posted in this thred" are 305. Is this the same deminsion you are talking about? His don't seem to pertrude past fender wells. I may not mind that anyway, just as long as it dosn't rub.
thanks for input
97Rob
Old Oct 26, 2005 | 08:18 AM
97Rob's Avatar
97Rob
Are you saying you wish you had put 17" wheels on front.
97Rob
Old Oct 26, 2005 | 08:21 AM
shurite44's Avatar
shurite44
nitto 275-40-17
Pics would be nice.
97Rob
The downside of reproduction wheels is the weight. With the wider wheel and the fact they are repo's you are adding around 20-30 lbs of un sprung weight. Probably 1-2 tenths in the qtr mile slower, worse ride and handling.
Old Oct 26, 2005 | 08:25 AM
97Rob's Avatar
97Rob
What are my options? I guess I would have to by factory ZO6 and have them cromed.
thanks for the responce
97Rob
Old Oct 26, 2005 | 08:27 AM
97Rob's Avatar
97Rob
Your car looks awsome. The pics are great and helpful.
Rob
Old Oct 26, 2005 | 08:28 AM
shurite44's Avatar
shurite44
97Rob
There are vendors out there that have already done that for you. They just cost a little more but you will have a much better wheel.
I am speaking from experience here, I already made this mistake.
Old Oct 26, 2005 | 08:31 AM
shurite44's Avatar
shurite44
http://www.westcoastcorvette.com/sho...b_cat.cfm?id=8
Here you go GM OEM wheels that have been chromed. Generally the chrome only adds 3 lbs per wheel.
Old Oct 26, 2005 | 08:38 AM
97Rob's Avatar
97Rob
I guess these wheels would cost $2300 W/ no core exchange.
97 Rob
Old Oct 26, 2005 | 08:40 AM
97Rob's Avatar
97Rob
How about 17x8.5 f 18x10.5 back, would you have rather done something like this?
97Rob
shurite44's Avatar
shurite44
97 Rob
What do you have now, wagon wheels? If so they probably don't take them as a core. I have seen GM chrome Z06 wheels on the for sale section before for around 900.
Edit: used of course.
Old Oct 26, 2005 | 08:41 AM
427Z's Avatar
427Z
well, i wish i had a 17 front or a 19 in the rear. as long as there was a one inch difference front to back in diameter
Old Oct 26, 2005 | 08:42 AM
97Rob's Avatar
97Rob
Heard 19's are tough sizes for tire selection.
Rob
To wheels 1" wider
Old Oct 26, 2005 | 08:43 AM
shurite44's Avatar
shurite44
Rob
I don't think there is a DR available in a 19
Old Oct 26, 2005 | 08:45 AM
427Z's Avatar
427Z
97Rob
that fine too for a street car. you're just going to have more under steer which is safer if you dont want the rear comming around you.
just whatever you like
Old Oct 26, 2005 | 08:48 AM
97Rob's Avatar
97Rob
I like safer, the original idea was the look of the set up.What is under steer?
Thanks for all the help.
97Rob
