Traction Control System
Old Oct 27, 2005 | 08:57 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Default Traction Control System
Can someone tell me how to turn the TCS off? This system, although it works as intended, doesn't do allot for performance.
Your comments are appreciated.
Bob
Old Oct 27, 2005 | 09:04 PM
SLPRC5's Avatar
SLPRC5
HMMMM............press the button on the console
Old Oct 27, 2005 | 09:22 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Turn it off, then push the button again and hold it down till it goes into Competitive Mode.... at least the ABS will stay on.
Unless you are alone on a track, with feather filled pillows as guard rails and a very good driver, no TC (off) is a
$.02 deposited.
Dave Q.
Old Oct 27, 2005 | 09:36 PM
GrayC5's Avatar
GrayC5
With the engine running, press the Active Handling button on the center console once. This turns both Active Handling and Traction Control off and the message TRAC/ACT HNDLG - OFF will display in the DIC. To enter the Competitive Driving Mode, press and hold the AH button (approximately 5 seconds) until the Competitive Driving displays in the DIC. The Competitive Driving Mode turns the TC off but leaves the AH on. With the second generation active handling (model years 2001 through 2004) you can engage the different modes while the vehicle is moving. For earlier model years, the vehicle must be brought to a complete stop. Each time the car is started, the system automatically defaults to both TC and AH on.
This is all covered in Section 4, Driving Your Vehicle, of your owners manual and you can find more info there.
Best be careful when turning TC or both TC and AH off as several here have learned the hard way. Best to save the TC/AH off and Competitive Mode for the track.
Good luck.
Old Oct 27, 2005 | 10:44 PM
SLPRC5's Avatar
SLPRC5
$.02 deposited.
Dave Q.
110% leave it ON!
Old Oct 27, 2005 | 11:09 PM
2KFRC5's Avatar
2KFRC5
$.02 deposited.
Dave Q.
ABS is always on. Can't be turned off. I think you were referring to AH.
Old Oct 27, 2005 | 11:46 PM
vetterlatethannever's Avatar
vetterlatethannever
That just about covers it!!
Old Oct 27, 2005 | 11:53 PM
b98's Avatar
b98
Old Oct 28, 2005 | 07:27 AM
BobbyG's Avatar
BobbyG
The other day I wanted to see what she had and decided to take it through the gears with 5500rpm shifts. Off the line Z06 has a tremendous launch but as the speed increased I noticed a pronounced cut back in power after each shift, for a split second.
My first Vette was a 1966 convertible, in 1974. A standard 327 4BBL with a 4 speed, how simple were they then. My 2004 Z06 is just a bit different. I picked it up this past June and have really enjoyed it but there's a whole lot more to these especially from a technology standpoint.
I'm still learning, even at 52
Thanks for your replays and explanations.
Bob
Old Oct 28, 2005 | 09:03 AM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Good luck.
Very good advice wise one!
Old Oct 28, 2005 | 10:25 AM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
$.02 deposited.
Dave Q.
It hard lesson to learn. Here is what can happen with TC off.
Old Oct 28, 2005 | 10:46 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
$.02 deposited.
Dave Q.
Old Oct 28, 2005 | 10:48 AM
Litre's Avatar
Litre
Spun my car in the middle of a road going 25MPH with AH/TC off, almost hit a tree. I'm damn lucky no one was in the road at the time. It doesn't take much, so be very careful. No real reason to take it off when not at the track anyways.
Old Oct 28, 2005 | 10:54 AM
southerncarparts's Avatar
southerncarparts
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
$.02 deposited.
Dave Q.
Old Oct 28, 2005 | 12:12 PM
2003Torch's Avatar
2003Torch
Comp mode at the track will slow down a very good driver. Instead use the active handling to tell you when you mess up. The goal is to go around the track as fast as you can and not have active handling kick on. If it does you made a mistake somewhere. if you can do this you can then consider turning it off after contemplating the possible ramifications may be high. Cheers!
Mark
Old Oct 28, 2005 | 04:03 PM
BobbyG's Avatar
BobbyG
My Z is absolutely mint and I'd like it to stay that way. The photo above makes me think GM put all those systems on my Z for a reason. The advise you've given makes allot of sense so I'll leave the TC and AH on, unless I can find an empty runway somewhere
Bob
Old Oct 28, 2005 | 05:01 PM
edensknight's Avatar
edensknight
$.02 deposited.
Dave Q.
To Traction Control System
