Rear View Mirror ????????
Old Oct 31, 2005 | 08:38 PM
dwspas's Avatar
dwspas
Default Rear View Mirror ????????
Anybody know how to take the inside rear view mirror off. Have to repair a wire that came off and the only way to get at it is when the mirror is removed. Thanks for your help.
Old Oct 31, 2005 | 08:56 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
I believe it is held on by a set screw that you unloosen with an allen wrench and then slide the mirror off of the bracket thats "glued" to the windshield.
Old Oct 31, 2005 | 09:10 PM
diyguy's Avatar
diyguy
You will need a torx bit (#10 - I think), loosen it a couple of turns, the slide the mirror upwards towards the top of the car until it slides off the windshield braket. You will need a small screwdriver (or similar), to get to the connector latch. Lift up and gently pull the wiring harness out of the mirror..
Simple job to do.
To Rear View Mirror ????????
