How do you close you hood?
Old Nov 7, 2005 | 03:26 PM
MR1911's Avatar
MR1911
I just ajusted mine last week , no matter how I closed it drop or push one side never would catch, so I was doing both.After adjusting the three 10 mm bolts and the rubber adjusters I can drop from about 6 inchs now , also lube those latches
Old Nov 7, 2005 | 03:37 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Is this a trick question? I mean, if I answer this will I receive spam mail, or something?
Something that seems so simple and so fundamental now requires a question and answer.
6 inches and let it drop, if it doesn't latch go higher.
Old Nov 7, 2005 | 03:56 PM
6 speed Sid's Avatar
6 speed Sid
Keep the latches it well lubricated and drop from about 6-10".
Old Nov 7, 2005 | 04:07 PM
edensknight's Avatar
edensknight
Originally Posted by vettecop1125
I lay mine down on top of the latches and then push down on each side right above the latch.
Old Nov 7, 2005 | 05:52 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I guess after reading all the repsonses.. it's safe to say either way works, huh?
Old Nov 7, 2005 | 06:02 PM
PEW01's Avatar
PEW01
Originally Posted by vermjpv
Same here!!!
12" Drop
Old Nov 7, 2005 | 06:30 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Originally Posted by Tigershark3
Drop about 12" from the center, otherwise one or the other does not latch.
Same here.
Poptops's Avatar
Poptops
Old Nov 7, 2005 | 06:33 PM
TheBigDog's Avatar
TheBigDog
Default Hood
What he said
The Big Dog
Old Nov 7, 2005 | 06:40 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
I know...stupid thread but hey, the more stupid it is the better it is here on the C5 side, right?
Looks like most here just drop it from the 6-12" range and since that's what I have been doing I was just currious.
I've been waiting for someone to say just slam it down
I tried the one where you just push the corners down but it just don't like the idea of one side locked at a time and it may cause stress on the hood.
Old Nov 7, 2005 | 06:45 PM
BlackVettesRBest's Avatar
BlackVettesRBest
That's pretty much what I do.
Old Nov 7, 2005 | 06:46 PM
Prosecutor's Avatar
Prosecutor
I just give it a little shove and allow it to come crashing down.
Old Nov 7, 2005 | 06:53 PM
  #33
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
That's the way my friend does it with his Ferrari F355. I figure if it's good enough for a Ferrari, it should be good enough for my vette. My hood still looks perfect, so I'll continue to do it my way until I start to see some signs that I'm doing it wrong.
Old Nov 7, 2005 | 06:56 PM
  #34
DAVS Y2K's Avatar
DAVS Y2K
Banned Scam/Spammer
Over 30 responses on how people close the hood.
Old Nov 7, 2005 | 07:37 PM
  #35
MyToyC5's Avatar
MyToyC5
Originally Posted by Tino
Me too
Same here!
Old Nov 7, 2005 | 07:43 PM
  #36
racecar2001's Avatar
racecar2001
My car has a little bit of the older vette symdrome. I need to kind of slam it on the drivers side to get it to catch. One of my winter projects to adjust the stop.
Old Nov 7, 2005 | 08:37 PM
  #37
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
Originally Posted by Target Chaser
I drop mine from about 12", no problems.
To How do you close you hood?
Old Nov 7, 2005 | 08:38 PM
  #38
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
We are FREAKS aren't we!!
Old Nov 7, 2005 | 08:41 PM
  #39
racecar2001
Update. Went out and adjusted drivers side rubber stop. Now it's perfect
Old Nov 7, 2005 | 08:52 PM
  #40
barkingowl's Avatar
barkingowl
Cruise-In IV Veteran
Cruise In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I slam mine.
