How do you close you hood?
Old Nov 7, 2005 | 09:03 PM
  #41
pcfred's Avatar
pcfred
St. Jude Donor '05
Originally Posted by vintage driver
I just drop mine from about 6 inches and it works.
The 6" drop for mine.
Old Nov 7, 2005 | 09:10 PM
  #42
JETZ's Avatar
JETZ
Originally Posted by DevilDog II
I do the same thing, but I keep a microfiber towel in the glove compartment that I put under my hand so that I don't leave smudges.
Dropping either my old, or new CF hardly ever worked!
Old Nov 7, 2005 | 09:30 PM
  #43
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
How do you close it, my question is: "How do you get it open?"
Old Nov 7, 2005 | 09:43 PM
  #44
Wolfmanjohn's Avatar
Wolfmanjohn
12" drop here, holding the hood in the center with a microfiber towel.
Old Nov 7, 2005 | 09:58 PM
  #45
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Just grab a corner and pull really hard...
Ohhhh! You meant how to open it in oooooone piece.... :o
Old Nov 7, 2005 | 10:00 PM
  #46
racecar2001's Avatar
racecar2001
Use a Works every time
Old Nov 7, 2005 | 10:05 PM
  #47
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Your hood opens from the front. Just turn the Corvette emblem clockwise and it will release the latch.
Old Nov 7, 2005 | 10:09 PM
  #48
J Z06's Avatar
J Z06
I tried the six inch from the top drop and my drivers side of the hood never closes correctly. I usually grab a nice soft towel and push it closed from the center of the hood.
Old Nov 7, 2005 | 10:25 PM
  #49
poolhustler's Avatar
poolhustler
Originally Posted by BobbyG
Is this a trick question? I mean, if I answer this will I receive spam mail, or something?
Something that seems so simple and so fundamental now requires a question and answer.
6 inches and let it drop, if it doesn't latch go higher.
Russ...
Old Nov 7, 2005 | 10:56 PM
  #50
Mr. Wonderful's Avatar
Mr. Wonderful
From: Slower than a speeding bullet................ Fort Lauderdale, FL
I have hired a guy to close mine.... I don't want to have to decide which way is best
Old Nov 8, 2005 | 01:10 AM
  #51
01QuickSilver's Avatar
01QuickSilver
I can't get mine to latch both sides unless I actually give it a light push as I release it from about 12 inches. Seems to want to latch only one side otherwise, then I have to go back inside and trip the release again (pita). Same problem on the other end of the car - hatch won't latch unless a door or window is open - also a pita....
Old Nov 8, 2005 | 01:25 AM
  #52
StingerZ16's Avatar
StingerZ16
With my Stingray it always closes from the 6" drop.
However, the Z16 has the carbon fiber hood and there is just not enough weight to close it by droping. Not even one side closes.
So, I have to do the push and wipe method.
(Push down on both sides and wipe with a Micro fiber rag)
Old Nov 8, 2005 | 07:22 AM
  #53
Husker67's Avatar
Husker67
Old Nov 8, 2005 | 07:36 AM
  #54
racecar2001
Mine was exactly the same way. I adjusted the rubber stop down a few turns on the side that wouldn't catch. Worked perfect after. You may want to give that a try.
Old Nov 8, 2005 | 09:39 AM
  #55
RatedX's Avatar
RatedX
From: Spring Hill, Florida Life is all about new beginnings;...TRY ONE!
St. Jude Donor '07-'08
Originally Posted by Dave1998
I drop mine from center , 12 inches, but 1 never latches first time
I still have nightmares from when my L88 hood cracked! in '68!!!
Old Nov 8, 2005 | 01:13 PM
  #56
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
I can't believe it, this thread has 55 postings!
Can't wait to get to the doors and deck lid!
Old Nov 8, 2005 | 05:06 PM
  #57
Darion's Avatar
Darion
To How do you close you hood?
Old Nov 9, 2005 | 08:02 AM
  #58
pmruss's Avatar
pmruss
I push (with micro towel) from the center of the backside till it passes the rocker point. That's the only way mine latches every time.
Old Nov 9, 2005 | 08:32 AM
  #59
Crushinator's Avatar
Crushinator
Same here.
Old Nov 9, 2005 | 10:50 AM
  #60
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
you mean nobody jumps up on the hood to cose it?
