[Z06] Oil Cooler Options?
Old Nov 8, 2005 | 07:36 AM
Rob's 73's Avatar
Rob's 73
Default Oil Cooler Options?
Need some recommendations on a oil cooler setup. I want some sort of thermostat or at least a manual valve. I only need the oil cooler when I go to the track. I've seen temps in the 290 range during a 25 minute run. Anybody have a custom setup less than the DR setup?
Thanks in advance.
Old Nov 8, 2005 | 04:36 PM
AU N EGL's Avatar
AU N EGL
I run the GM T1 set up with a seperte oil cooler & accu-sump.
Check with Fred Beans. they have the t1 oil cooler system
