beware 50th owners
Old Nov 8, 2005 | 11:50 AM
2pedala's Avatar
2pedala
Default beware 50th owners
I wanted the word out. i sprayed OXY CLEAN on a spot on my shale color carpet . behind my seat. did great decide to spray all of front drivers side just lite clean over. ten minutes later all of it turn brite neon yellow. called company they said no reverising it so dont use OXY CLEAN carpet an spot remover
Old Nov 8, 2005 | 11:52 AM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Woe, that really sux! Thanks for the warning!
Old Nov 8, 2005 | 12:06 PM
Last Mango's Avatar
Last Mango
Sorry that happened. Thanks for passing along a warning to everyone. I hope you find a good deal on replacement carpet.
Old Nov 8, 2005 | 12:16 PM
jrose7004's Avatar
jrose7004
Wow good thing you didn't spray it where you could see it!
Old Nov 8, 2005 | 12:18 PM
Preciouslady's Avatar
Preciouslady
Thanks!!! I will not use that on our carpet!!!
Old Nov 8, 2005 | 01:10 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Sorry. That sucks....
Great heads-up for everyone else though
Old Nov 8, 2005 | 03:17 PM
blh's Avatar
blh
Default Hydrogen Peroxide
I can't comment on the use of Oxyclean but I can suggest this. I have a 2004 CE convertible with Shale carpet. When I got the car, there were some stains in the passenger carpet, some of them quite yellow. I took some hydrogen peroxide (get it at any drug store, it is used as a disinfectant) and wiped it liberally over the stains (I pretty much soaked the stained parts of the carpet). After about 24 hours, the stains faded completely out. I can't comment on how this affects the long-term durability of the carpet, but where you already have a problem, I think that it might be worth a try. Just try it in a small spot if you want to test it. In my own experience I was pretty amazed. The carpet looked completely new afterwad. I had already tried various stain removers, including Oxyclean (which didn't do much). Anyway, I hope it works for you. Note it takes overnight; just leave the carpet wet with hydrogen peroxide for it to work.
Of course, the alternative is to take the car into a good detailer and see what they can do. Best of luck.
Old Nov 8, 2005 | 03:23 PM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
Pics?
Old Nov 8, 2005 | 03:37 PM
edensknight's Avatar
edensknight
Whoa! That is terrible! Thank you for the warning.
Old Nov 8, 2005 | 03:46 PM
jim213's Avatar
jim213
What a bummer. Sorry you had the problem. Guess I will stay away from that as well.
Old Nov 8, 2005 | 03:53 PM
OrangeVegaGT's Avatar
OrangeVegaGT
St. Jude Donor '06-'07
Very good information. May I suggest that you change the thread title to something like "Beware Shale Interior Owners". Some of us with CE's need to read this also.
Old Nov 8, 2005 | 03:56 PM
waupachino's Avatar
waupachino
That is Terrible. Hope you can get it worked out.
Old Nov 8, 2005 | 04:00 PM
03clyde's Avatar
03clyde
I wonder if it only affects that color or are others in jeopardy as well??
Old Nov 8, 2005 | 04:12 PM
KMeloney's Avatar
KMeloney
Read his post again -- he DID spray it all over the one side! Eek!
-Kirk
Old Nov 8, 2005 | 04:30 PM
LB04CE's Avatar
LB04CE
That's terrible,,sorry to hear that happen.........
Old Nov 8, 2005 | 06:32 PM
Thanks for the heads-up. Sorry that you'll have to get new carpeting.
Old Nov 8, 2005 | 06:36 PM
Rhode Warrior's Avatar
Rhode Warrior
Jesus, haven't you ever seen those commercials? It turns water with red dye in it to clear in about 2 seconds. What did you think would happen? That's like saying don't put your finger in a mouse trap, it snaps at you.
To beware 50th owners
Old Nov 8, 2005 | 06:51 PM
b98's Avatar
b98
Old Nov 8, 2005 | 07:39 PM
rudolph schenker's Avatar
rudolph schenker
Old Nov 8, 2005 | 07:43 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
"Resolve" works well on light carpet. I use it in the house and the cars. I've never had it take out colour, only the stains. You can buy it an most grocery stores.
