I'm buying some OEM wagon wheels for my project ('89 Jag XJ6 with an LT1), so I'll be running adapters. My question is how are the centercaps on those wheels attached? I don't have the wheels in hand, so I can't look. I'm used to typical GM with double-threaded lug nuts, but that doesn't look to be the case. I just want to buy the right lug nuts. Thanks!
Best I can remember, on my '03 stock wheels, they are springy plastic with a barb on the end that holds it on once you push it in and easily removable if you have the wheel off. The whole thing's plastic, as I recall. There are indentations so the lug bolts will fit in, but they are not attached to the bolts.
Uhh, no he didn't, or this thread wouldn't have continued.
"It's some sort of spring-loaded snap on."
It snaps on to what? The wheel? The lug nuts? Who the hell knows? Chicago actually gave me the information I was looking for. Thanks for the more descriptive answers.
Easy big guy. What would you think it snaps to, the windshield?
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
It snaps to the centre hub hole. It fits over the lugs. If you use a standard lug nut like those that came with the wagon wheels you shouldn't have any clearance problems. I wouldn't use any lugs that stick out past the centre section of the wheel.
Can't we all just get along???
First time I've seen someone act this poorly in the house.
I deleted all my "questionable" posts. If he'll do the same, I'm done. I tried to kill the entire thread, but I don't suppose I can do that, huh? I'll keep looking. Thanks for all of the replies.
To answer your deleted question ... no you don't ... definitely. The natives are friendly and helpful unless provoked ... then ... watch out!
He wasn't provoked, not was his initial comment helpful or welcomed. I asked a simple question, which at that point, had NOT been directly answered. Had he taken the time to answer the question instead of incorrectly stating that it HAD been answered, we wouldn't be here right now.
