Right door power problem
Old Nov 11, 2005 | 08:38 AM
FrankieC's Avatar
FrankieC
Default Right door power problem
Hi All
The power to my right door does not work window, and door locks
any items is there a connection in the door that could have come loose I had some audio work done a while ago
It is 2003 vert
thanks
Old Nov 11, 2005 | 08:55 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
just inside the accordian....inside the car.
There's a wire connection. That comes loose quite often. Take them apart and clean the contacts, and securly fasten the connection, that *should* fix your problems!
Chris
Old Nov 11, 2005 | 09:00 AM
FrankieC's Avatar
FrankieC
Stangkiller
Where is that connection
Old Nov 11, 2005 | 09:05 AM
Stangkiller
Originally Posted by FrankieC
Stangkiller
Inside the rubber accordian between the door and the car. If you follow the wires to the car body side. You'll find a nice big connector, take it apart clean both sides and securly fasten the wires.
Chris
Old Nov 11, 2005 | 07:36 PM
edensknight's Avatar
edensknight
Chris
To Right door power problem
