dimming lights
Old Nov 10, 2005 | 03:34 AM
SuiVette's Avatar
SuiVette
Default dimming lights
Hello all, i really need your expertise on this one.
Its seems to happen at night with the light on more than any other time. But with driving on the freeway i can see my light dims and the car will pull slightly to the left and a, "ACTIVE HANDLING" message on my DIC will pop up.
The volt meter on the dash never goes below 13v. I have replaced the battery to a optima and the problem persists.
Does this sound like a grounding issue and should i take it to an auto electronics shop for diags?
Thanks for the help,
Sui
Old Nov 10, 2005 | 11:51 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I'd say there is an electrical problem without a doubt - maybe you have a failing alternator, could be a grounding issue.
I suggest that you send a P.M. to Bill Curlee who seems to be the resident expert on this type of issue and maybe he can offer you suggestion....good luck!
Old Nov 10, 2005 | 03:24 PM
CJM138's Avatar
CJM138
I have the same dimming issue but my headlights only dim when I put the windows up on down. They only dim slightly, but it annoys me. It makes no sense to me... anyone else have this problem?
Old Nov 10, 2005 | 11:46 PM
jessejay356's Avatar
jessejay356
The window motors require a lot of juice. I would say that is not uncommon to see lights dim. But if it is excessive maybe something is wrong with the battery or charging system.
Old Nov 10, 2005 | 11:48 PM
derekod's Avatar
derekod
mine does the same thing!
Getting a red top soon...
Old Nov 11, 2005 | 12:29 AM
CJM138's Avatar
CJM138
It's not excessive, it's very slight and probably unnoticeable to everyone but me. The battery is fine, pretty sure it is running at above 13 volts.
Old Nov 11, 2005 | 12:34 AM
CJM138's Avatar
CJM138
maybe it's a black coupe problem,
Old Nov 11, 2005 | 01:19 AM
derekod's Avatar
derekod
seems us black vette owners are always getting the short end of the straw...
Old Nov 11, 2005 | 12:38 PM
CJM138's Avatar
CJM138
seriously though, nice ride man. I was looking at your cardomain page and she's just like mine.
Old Nov 11, 2005 | 07:21 PM
edensknight's Avatar
edensknight
Old Nov 11, 2005 | 07:56 PM
SGT. PYLE's Avatar
SGT. PYLE
I have the same problem but if I adjust the seat it really dim's the lights even more so that the windows. I read somewhere that this is normal but it really bugs me and GM should have corrected this annoying gremlin.
To dimming lights
