Should I unhook the negative everytime?
Old Nov 12, 2005 | 09:28 PM
VET 350's Avatar
VET 350
Default Should I unhook the negative everytime?
I have a 92' and a 04' Corvette.
I only drive them 3 or 4 times a month since I have a truck to drive to work (a plant)
What's the best way to keep the batteries from running down?
Should I unhook the negative from the battery everytime?
Thanks in advance,
VET 350
Old Nov 12, 2005 | 09:41 PM
pcfred's Avatar
pcfred
St. Jude Donor '05
Battery Tender.
Old Nov 12, 2005 | 09:43 PM
Kevin G's Avatar
Kevin G
I'd say a "float" type charger such as a BatteryTender(tm) is the best answer to the dilema of keeping batteries charged in infrequently operated vehicles.
I used one myself on a motorcycle and it probably saved me from buying at least 3 or 4 new batteries over a span of several years.
Old Nov 12, 2005 | 09:44 PM
tiojames's Avatar
tiojames
Default unhook batteries
Pickup a couple of battery tenders fron Harbor Freight-$9.99 each.
Old Nov 12, 2005 | 10:00 PM
VET 350's Avatar
VET 350
How does a battery tender work?
It plugs into a outlet and attaches to the negative and positive?
Old Nov 12, 2005 | 10:53 PM
az57chevy's Avatar
az57chevy
If you drive them 3-4 times a month I don't think your battery will EVER run down
Old Nov 12, 2005 | 10:55 PM
NOWUCME's Avatar
NOWUCME
C6 of Year Finalist (stock) 2019
It senses when the batter goes below a certain voltage and comes on. Then it goes off after it reaches a certain voltage....never supposed to let the battery get to low, and won't overcharge it and damage it that way....it's usually a very small charger and easy to handle.
To Should I unhook the negative everytime?
