Wheel clearance & Alcons
Well, my second set of wheels arrived Friday. Better clearances, but they still hit the corners of my calipers. I suspect my options are to have HRE build me yet another set, but these would likely have a greater positive offset, resulting in greater bearing stress and a more protruding wheel. Alternatively, I can grind the leading edge off the corners of these pricey rear 4-pot calipers. I’ll call Baer tomorrow and see what they think, and also give HRE a call to find my best option.
An interesting hobby
You have discovered the challange with BBKs. The wheels need the proper offset to fit over the calipers.
Plus with those big rear tires, my guess is they will stick out beyond the fender. Tubbing is not an option and do 345s even fit on a 12" rim ??
If HRE did not know what the proper offset is for BBKs, try CCW or Kodiak.
Normally only 3 piece racing wheels have the offset for BBKs
Good luck
