I have an 01 Z06. Sometimes my turn signals stop working while driviing. They start working after sometime by themselves. Has anyones seen this??? what could be the problem??
Thanks in advance.
Sorry for the earlier title
Reason: changed the title but the main title is still the same.....???
Your hazard switch is going bad... it's a know problem. It's the switch that controls the hazards (duh) when you push the button with the red triangle. When the blinkers stop working you can push the hazard button in and out a few times to try and make it work, but ultimately you'll have to pull the dash and replace the switch, fortunately for me I had it covered under warranty.
ENGLANDGREEN just changed his and solved his problems! There is a SHORT CUT procedure that you can try! Pry off the switch cover. Remove the radio, access the bottom of the switch fron the area where the radio was. There is a clip on the bottom of the switch. push it up and push the switch up. Hit the exposed lip of the switch in the hole where the switch cover was with a punch and a hammer and the switch will pop out! Contact EG for a complete write up on the procedure.
