LAPD Heat/Stiffining Plate Question
I have been through the search for keeping the tunnel of my Z06 cool. This is what I would suggest that you try:
1) Order the Thermo-Tec tunnel heat shield - http://www.thermotec.com/products/full/16570/16570.html
2) Once you have the tunnel shield, go to back to the shop that put both the OEM plate and the Ceramic-coated plate on you car and have them remove the OEM plate and install the Thermo-Tec tunnel heat shield below the Ceramic-coated plate. Those two pieces together will significantly reduce your tunnel temperature.
Been there, done that.
How much is that thing? They dont list prices...
