Need extra key
Old Nov 16, 2005 | 10:50 AM
skelly1's Avatar
skelly1
Default Need extra key
I only have one key for my 99 FRC. Is it worth paying the 75 bucks the dealer wants for a second key or is there a cheaper route? Thanks.
Old Nov 16, 2005 | 11:21 AM
vertc51116's Avatar
vertc51116
From: Mustangs are like Tampons.. Every P*$$* has one!
If you bought the key new I don't think there is a cheaper way (unless you have the tools to do it yourself) If you bought it froma smaller private dealer try what I did. I gave them 2 keys with my trade in and they gave me only one key so I had them make me an extra. If that doesnt work ask them how much it would be. Maybe the used car dealer would be less expensive than a chevy dealer. Try it. GOOD LUCK.
Old Nov 16, 2005 | 11:30 AM
kwest2u's Avatar
kwest2u
Default $75?
Wow, had a key made at a Chevy Dealer and it only cost me $45. And that was here in the NorthEast where everything is $$$$$$$. Where you from?
Old Nov 16, 2005 | 11:36 AM
rws.1's Avatar
rws.1
Take your existing key, and measure the resistance across the VATs pellet ... using a digital voltage (multimeter) If you don't have one go to radio shack and ask them to show you how their demo one works using your key as the tester...
Do a search in C5 general on VATS code or VATS table.
Your will find a series of posts that give the key (pellet) number for that resistance (ohms)
Get online , go to eBay and search for VATS key
buy one that is for your model year and matches your key (pellet) number.
Take it to any local place that cuts keys...
You should be done for $15-20 all in.
Good Luck
Old Nov 16, 2005 | 11:41 AM
rws.1's Avatar
rws.1
follow this thread for the key (pellet) number corresponding to the measured resistance values
http://forums.corvetteforum.com/show...e&forum_id=103
Old Nov 16, 2005 | 11:46 AM
Togo's Avatar
Togo
dayum - that's good advice - wish i had thought of that before i went to the dealer!!!!
Old Nov 16, 2005 | 01:12 PM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
Good Luck
Or you could go to a locksmith or key maker and get a new one like I did for $35
Old Nov 16, 2005 | 01:38 PM
matt24's Avatar
matt24
If you know the resistor you can get one from ecklers.com for 14.99.
Old Nov 16, 2005 | 03:36 PM
JT-C6's Avatar
JT-C6
Cruise-In IV Veteran
St. Jude Donor '03-'06-'08-'10-'11
Yes, get a blank key with the correct VATS number and take it to a key shop or locksmith. The whole process should cost you less than $10 for a double sided key cut and probably $10 for the blank itself. I got one made @ Carlisle for around $15. I also had one made without the VATS pellet for door entry purposes only for $5. Not a bad idea to keep a nice flat plain key in your wallet and keep the real one with the VATS pellet hidden somewhere in the car.
To Need extra key
