Active Handling - deal breaker?
Chris
One time on the interstate, I had to swerve to avoid a bed liner that flew from the pick in-front of the Van that was right in front of me...Active handling kept me from losing control.
You can drive a C5 hard and have fun with it but its not the most precise car. I don't find the steering quick enough to really bring the back end around and play with the car.
I've turned it off and played with the car a bit. Its just a tough car, at least to me, to hang out and control easily.
My Ls1 powered 93 Rx7 was easier to drive in a slide than straight. I guess I'm comparing the C5 against it, but with the LS1 I could bring it around a corner, step out the rear, drive the thing at a 30 degree angle like it was nothing, little snap of the wheel and it straightens right out. I can't find the room, or the ***** to really try that in the C5
What does all that mean? I'd try more 'stupid' stuff in the Rx7 without any electronic aid at all then I would be willing to even think about in the C5 with the AH turned off.
I'm sure part of the tuning of the C5 comes from the fact it has AH. Companies tune around the car, its chassis, engine, and electronic aids.
C6's from what I have been told can be downright scary with the AH off.
I've driven at the track in competitive mode and for sure it has made me 'faster' in certain sections, very fast wide turns where you are at WOT. Sometimes the AH came on, sometimes it didn't. In situations like that, regardless of driver skill, for fun I'd rather put it to the floor and not have to steer out of a slide at 100mph.
I think GM did a pretty good job with the tuning on the AH also. It lets you have a decent amount of fun without intruding and as others have said, it sure can save you.
I had my line lock leaking. Brake fluid would puddle on the cradle, then over 80mph it would spray onto the back tires. Cruising along at 90mph the car just went 30 degree's sideways for no reason. AH came on and brought the car back in line. Could I have done it? Maybe but most likely the way it uses the brakes brought it back faster than me steering since I was only really using the front wheels.
So in the end...I would get it. You can always turn it off or turn it down in competitive mode. For those unknown moments, especially if you drive it in poor weather its well worth it and I would only buy the car if it had it.
I never would have activelly sought out a car with AH when I was shopping, but I'm very glad that the car I found has it. I've had mine kick in during an emergecny lane change, in an intersection near a car wash (lots of soap and water on the road) and once when I wasn't really paying attention and bolted into a busy street to make a left turn.
XmP
Should I buy another vette in the future, it wouldn't be a deal breaker for me at all.
There was a Forum member who totalled his new Z06, AH was off. Although a good driver, he swerved to miss an animal that jumped out in front of his car. He said that he believes that if AH was on, he would not have lost control.
I always leave AH on. Running through the mountains a C5 driver behind me ran without AH (he felt it was too instrusive - 2000 coupe). Going through a series of S turns @ ~120 my AH kicks in on the last S. He came out of it side-ways into a 180 in the other lane. Fortunately no one was coming the other way.
If AH saves me just one time during the length of time I own the car...IMHO it is worth it. BTW after changing stabilizer bars, shocks, wheels & tires, AH almost never comes on any more, where for me when stock it was quite frequent.
