[Z06] Installed just Ring and Pinion?
Old Nov 17, 2005 | 11:16 PM
Mr  X's Avatar
Mr X
Default Installed just Ring and Pinion?
Has anybody ever Installed just the Ring and Pinion and not the entire pumpkin?
This looks like a much cheaper way to go. Would there be any whining issues due to incorrect back lash?
Thanks!
Old Nov 18, 2005 | 07:15 AM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Make sure you have someone install the gears that know what they are doing, incorrect backlash settings will result in excess noise.... and yes just gears would be cheaper.
Old Nov 18, 2005 | 09:04 AM
KMeloney's Avatar
KMeloney
Thanks!
If I'm not mistaken, the "pumpkin" on these Corvettes is NOT like a standard rear. They're a contained unit, and sold only as a unit. Crawl under your car, and you'll see that this is not a standard pumpkin.
I don't believe you can simply swap gears in a C5. You need to replace the whole unit.
-Kirk
Old Nov 18, 2005 | 07:09 PM
Mr  X's Avatar
Mr X
Default ttt
ttt
Old Nov 18, 2005 | 08:32 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
You can purchase and install just the ring and pinion. But, unlike rears of the past this one is quite finicky and it takes someone who has done a C5 rear a few times to get it right. That is why most people just replace the entire unit. If you have a good shop in your area that has done a few before and can get it right the first time then by all means go with just the ring and pinion. But, from what I've read here, even the good shops still have problems with gear whine sometimes.
Best of luck.
Old Nov 19, 2005 | 06:30 AM
RandyVettes's Avatar
RandyVettes
Life's Short. Drive Hard.
Cruise-In VII Veteran
St. Jude '03-'04-'05-'06-'07-'09
I had a 4.10 ring and pinion swapped into mine. The gear set was inexpensive but the labor killed me. All-in-all if you can find a complete carrier containing the ratio you need, thats a much easier swap. In the long run I think you will find the total costs comparable.
Old Nov 25, 2005 | 02:39 PM
starshifter's Avatar
starshifter
I'm really ignorant when it comes to gears, so:
1)Is the gear whining the same with 3.90 as it is with 4.10?
2) If your rear end was relatively new (10.5K miles in my case), would you rather keep it and change the ring & pinion or would you exchange it for a rebuilt one?
Old Feb 4, 2006 | 04:28 PM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
I'm interested in these questions as well.
Also, what brand of ring/pinion is best?
Any other parts needed?
Old Feb 4, 2006 | 06:14 PM
F1_SS's Avatar
F1_SS
The gear whine has nothing to do with the size of the gears, it has to do with the gears not being either 1. Set up right, 2. not being "broken in" right.
Old Feb 5, 2006 | 08:39 PM
DT's Avatar
DT
Howdy!
I have heard/read that the higher (numerical) gears have "steeper" angles (than lower gears), and that steeper angle generates more whine/friction. (so 4:10's would be noiser than say 3:73's)
I have no experience with this myself, just read it a few times.
Any truth to this?
Old Apr 23, 2006 | 12:51 PM
robinde's Avatar
robinde
Default 3:73 gears installed
The chevy dealer installed a set of 3.73 gears in my o4. No noise difference from the stock 3.42. Go with the ring and pinion.
Old Apr 23, 2006 | 03:57 PM
BQuicksilver
I also just got my diff upgraded to a 3.73 without any noise on accel or decel. Very happy with this upgrade.
Old Apr 24, 2006 | 09:46 PM
Roadrace65's Avatar
Roadrace65
Gear Swap in any diff must be done right, with the proper tools and knowledge. I’ve built more than quite a few diffs from C2’s up to current. Granted, the C5/C6 diff is different in allot of ways, fundamentally it’s the same beast. Gear noise is due to improper pinion to ring relationship more so than backlash. The patterns that I get on the C5’s are never quite as sweet as those I typically get with Dana gear sets in C4 Dana 44 cases. Ask me again after I build 10 more, that could change.
Break in is a funny subject..I’ve built diffs for guys that hammered them mercilessly from day one without problem…..I run my new diffs easy for a short while….and then hammer them mercilessly.
The C5/C6 diff requires a bunch of unique set-up, build and measurement tools. Is it Voodoo?...No…It’s just new and different. To date, the rebuild kits available don’t contain all the necessary shims. I’m machining the pinion bearing preload shims myself. Can your typical local gear shop do it?...maybe not…..But there’s’ plenty of guys like me doing it right I’m sure.
To Installed just Ring and Pinion?
