Battery Draining
Old Nov 18, 2005 | 10:29 AM
joecookie's Avatar
joecookie
Default Battery Draining
I have a new battery that was going dead every 24 hours and had the dealer work on it, they said that the battery acid had gotten on the harness and after days finally said it was fixed. Now it is drianing down after 48 hours any ideas on what is going on?
Old Nov 18, 2005 | 02:30 PM
Yoggi's Avatar
Yoggi
I assume they checked the battery to be sure it wasnt bad. Other than that you have an electrical drain somewhere. If dealer didnt fix, get your money back or have them trace again.
Old Nov 18, 2005 | 03:13 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
You could place a DVOM on the battery and start pulling fuses, one at a time. When you find the fuse that stops the drain - you've at least narrowed it down to the circuit and everything that's on that circuit. You might check obvious things like a glove box light that stays lit, the underhood light, do you have an accessory plugged in that stays energized with the ignition off, etc. Do you have the courtesy lamps on? How about the reading lights on the bottom of the mirror?
Another easy way is park the car in a dark garage and see if you can spot any light coming from anywhere.
Is the "new" battery good - it might have a bad cell. Take a known good battery and see if the same thing happens.
Beyond that - I'm fresh out of ideas.....
Old Nov 18, 2005 | 04:04 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I hope you cleaned up that acid?
The drain could be a result of the acid on the wires, Page Bill Curlee and see what he thinks
Old Nov 18, 2005 | 04:59 PM
Der Flieger's Avatar
Der Flieger
Default Battery drawdown
Check the light in the glovebox and see if it is in fact going out when the door is closed. Mine was staying lit until I adjusted the switch.
Old Nov 18, 2005 | 05:54 PM
edensknight's Avatar
edensknight
Excellent advice from Rands.
Old Nov 18, 2005 | 06:36 PM
screw991le's Avatar
screw991le
All our cars have RAP and run down protection. The any light would be shut off after about 12 mins. From what I understand. So if you left the interior lights on, they should go out, yes?
Old Nov 18, 2005 | 07:25 PM
blacksedan87
If you leave the door, hood or trunk open, Rich, they will eventually go out. But if the switch is bad or if you've manually turned on the interior lights, or a mirror mounted map light - I don't think they go out. Same holds true with the glove box. Of course this doesn't account for malfunctions and the light is on and won't go out. Might have to pull the bulb. I also read here of someone with a failed power antenna that stayed on constantly and eventually drained the battery.
It's the simple stuff that we sometime overlook - and I am offering a suggestion. Might be something more complicated, but I hope not.
To Battery Draining
