What did they do different?
Old Nov 19, 2005 | 11:50 PM
Black94Camaro's Avatar
Black94Camaro
Default What did they do different?
In 2001 they gave the coupe 5 more horsepower from 2000. What did they do different to give it that extra 5?
Old Nov 20, 2005 | 12:38 AM
vetred's Avatar
vetred
they,........DIDNT,....no realy the way that horsepower was calculated was changed,....no realy! actualy we ALL got about 5 H.P. more
Old Nov 20, 2005 | 12:47 AM
Goonie's Avatar
Goonie
they put that vortex turbine air induction... and those propeller tips!
i got the right stickers so were about even!
btw: all i think that changed was the oil dipstick location...
Old Nov 20, 2005 | 12:51 AM
GrayC5's Avatar
GrayC5
The model year 2001 5 Hp increase on the LS1 was mainly due to the newly designed composite intake manifold and the low end torque increase from modifications to the cam shaft:
Model Year 2001 Press Release - More Performance...
Old Nov 20, 2005 | 01:06 AM
01QuickSilver's Avatar
01QuickSilver
Many changes for 2001... here are some highlights:
return to 28# injectors for all models
85MM MAF with integral temp sensor (versus 74mm with separate plug for IAT)
LS1 cam profile changed to: .500/0.500, 198/208 on 115.5LSA (From:
0.472/0.479, 202/210 on 117)
All Corvettes now have the LS6 intake manifold
All Corvettes now have the LS6 engine block which includes a beefier oil pump
LS1 changes result in new output of 350 HP @ 5200 RPM and 375 Ft Lbs of torque @ 4400 RPM (MN6)
Pup cats added to all models
Stronger synchros in all transmissions
Exhaust manifolds revised (5hp regained) - thin wall cast replacing SS
manifolds
Torque Tube changed from metal-matrix composite to aluminum alloy 6061, increased in dia from 55 to 63 mm.
Driveshaft couplings have also been upgraded on manual-equipped models for additional strength and durability
Indeed, it was a good year!!
Old Nov 20, 2005 | 01:49 PM
Black94Camaro
Thank You Gray and Quicksilver!
Old Nov 20, 2005 | 02:50 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
More blinker fluid was added to the left blinker
Old Nov 20, 2005 | 04:09 PM
NSTG8R's Avatar
NSTG8R
dead on .. as usual.
Old Nov 20, 2005 | 04:23 PM
edensknight's Avatar
edensknight
manifolds
Bingo.
To What did they do different?
