Question on Error Code P1416???
Old Nov 20, 2005 | 06:07 AM
GLF's Avatar
GLF
Default Question on Error Code P1416???
I've printed out the guide as to what the different error codes are, and I'm used to periodically zeroing out the codes when the check engine light comes on. But, I'm just not sure of the consequence of the above noted error code.
From the listing, P1416 indicates AIR System bank 2-B. What does this indicate? Is there any significance or consequences to it?
Now, I won't deny that the initial sightings of this code started after I removed the screen from my MAF, and there's no putting it back, as the screen is, shall we say, slightly distorted around the edges.
Thanks for any info and feedback!
Old Nov 20, 2005 | 08:18 AM
jers98vet's Avatar
jers98vet
Time to change the air tube check valve that is located behind the engine. You'll probably have to remove the intake to gain access.
Old Nov 20, 2005 | 09:52 AM
jman1's Avatar
jman1
i had that code last year... it is either for the air check valve behind the intake.... or a loose air hose...... some said you could replace the valve without removing the intake but i couldn't do it...... i took it to the dealer.... during the test they preformed to trouble shoot the problem they fixed it told me there was nothing wrong i'd check all the air hoses
To Question on Error Code P1416???
