[Z06] c5 z06 possible alignment problem
Old Nov 21, 2005 | 01:02 PM
itsmeek's Avatar
itsmeek
Default c5 z06 possible alignment problem
well guys and gals,
i notice that this car will go wherever it likes on it's own from time to time. especially when i brake. it seems as if the pads are worn evenly and doesn't seem like one side grabs harder then the others. i notice that on the highway sometimes it will also go where it wants unless i really hold the steering wheel tight.
is this normal on these cars or should i go get it aligned?
thanks!
meek
Old Nov 21, 2005 | 01:34 PM
JiminVirginia's Avatar
JiminVirginia
Not normal.
Sounds like you have a caster and/or toe problem.
It happens, especially if you track your car or run rough roads, or if you lowered it by yourself without getting an alignment.
I'd get to an alignment shop if I were you.
nightboom's Avatar
nightboom
I noticed this getting worse when my factory tires got worn. I just replaced the Goodyears with Kumhos and no longer have the problem.
Old Nov 21, 2005 | 01:51 PM
itsmeek's Avatar
itsmeek
thanks for the replies fellas!
i need new tires anyway- might as well do it all at once.
Old Nov 21, 2005 | 02:43 PM
NeverT00Fast's Avatar
NeverT00Fast
Mine was doing exactly the same thing, but just alot worse after I lowered my car. When I took the car in for alignment, the guy told me that my rear tires were like \ \ instead of l l The toe was way off, and so was the caster.
Old Nov 23, 2005 | 01:20 AM
onwallstreet's Avatar
onwallstreet
Where do we get the specs? I'd trust the dealer specs of course but price wise, would rather go to an alignment shop.
Old Nov 23, 2005 | 07:30 AM
NeverT00Fast
http://forums.corvetteforum.com/show...75&forum_id=49
Old Nov 23, 2005 | 08:41 AM
AU N EGL's Avatar
AU N EGL
Rember that roads are crowned to allow rain water to drain off. So cars naturally pull to the right if there is a perfect alignment.
Go find a realtivly flat parking lot and do a few brake tests.
Getting your alignment checked is a good idea.
front
-.8* to -1.5* camber
6* caster and equal on both sides
1/16 to 1/8 toe out
rear
-.5* to -1* caster
1/16 to 1/8 toe in
Old Nov 23, 2005 | 08:56 AM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
A grooved road will do this, I seem to notice it at intersections that have alot of truck traffic, mine seems to pull from time to time in these areas but on the highway/smooth roads its fine.
To c5 z06 possible alignment problem
