Certainly not my idea...saw them advertised in an Auto Mag somewhere.
I purchased four small magnets, 1/4 inch thick, 3 inches long and 3/4 inches wide. I place these magnets on the side of my oil filter. I have been doing this for about six months. I have never lost a magnet.
On my first oil change, I cut open the filter and found 4 areas of grey "sludge" on the side of the filter about the size of the magnets. I believe the magnets are removing ultra fine particles of metal from the oil.
You can buy "aftermarket" magnets for about $50.00 or do as I have done for less than $5.00. Mine actually cost much less as I purchased them in Hong Kong but I have seen them at Harbor Freight for about $1.00 each.
I fly Internationally for FedEx and bought my magnets in Hong Kong. I saw them available at a Harbor Freight store here in Boise, ID for about $1.00 each.
I am not really sure what you are talking when you mention Flexible Magnets. I imagine any magnet would work. As I said the ones I use are just 1/4 X 3/4 X 3 inches and I happened to have four of them, so I used all four. I imagine just one magnet would do the job.
The ones that are usually advertisements and are about the size of business cards. I was thinking wrapping those around the oil filter to even out thought the globs.
Have an old disc drive? Take it apart (good practice anyway) and remove the two magnets inside (one on each side of the disc). These are incredibly strong. Stick it to the side of the filter, it sure won't fall off and will attract any metal particles that comes within its field.
Mike
That's a great idea. I bought drainplugs with magnets for the engine, manual trans, and diff. Same idea - when you drain the oil you'll see the end of the drainplug has a kind of a metal sludge stuck to it.
This is a common trick after rebuilding a motor so new shavings from brake-in stay in the filter. you can tape a magnet to it as well so it wont fall off. its cheaper than a new crank and bearings
Anyone interested in going in on some of these? The quarter sized ones would work perfect.
good call - you could put one on the drain plug, one on the filter and i'm sure one on the diff and trans and think of the savings - aren't those magnetic drain plugs like $10+? if they are that strong, i'd feel safe putting one on the end of my drain plug with no fear of losing it EVER!
and for $20 you could outfit several cars
that's a good deal, i might just order those!
i went ahead and ordered them - it was like $7.50 to ship so not a bad deal altogether!
thanks torchredfrc for the link! now both my vettes will get "protection"
***EDIT*** FYI - none of those are quarter size - they appear to be the size of watch batteries - heres the pic from their gallery
$13 for 1 magnet and 1 drain plug - you're better off with the 87 count pack for $20 plus ship - you can out fit every car in your neighborhood for that amount!
i'll let you all know how they work out when they arrive!
Oops, I noticed they were smaller than the quarter after I posted. I was referring to the ones on the far right in the picture. I don't know if I would feel comfortable putting one of these inside the drain pan (on the end of the plug). To me, that is just asking for trouble... I would hate for the thing to come off in the oil & that would be just my luck.
