Oil Level
Old Nov 22, 2005 | 04:15 PM
SKULLC7's Avatar
SKULLC7
Default Oil Level
Hi Everyone, Im New To The Forum.
Recently I Purchased A Red 01 A4 (21k) From A Private (orig) Owner. Via The Forum, I Learned That The 01 Was Proned To Burn Oil. I've Monitored The Oil Level Since Learning Of This Issue.
My Question Is When Is The Oil Level Most Acurate, Before Start Up Or After Running The Engine For A While.
The Oil Stick Reads Full Before Start Up But, Shows A Quart Down After Running The Engine For Several Minutes.
Old Nov 22, 2005 | 04:25 PM
rws.1's Avatar
rws.1
A quart down after running sounds a bit much... but anything is possible. When you shut the engine down all the oil drains back into the pan except for the residual film on coating all the pathways.
I always check my oil in the morning with the engine cold so that it is always consistent.
Old Nov 22, 2005 | 04:26 PM
BlueDragon's Avatar
BlueDragon
Always check your oil before start up. Best in the morning before you start it for the first time.
change your oil warm and let it drain for a while.
Old Jan 2, 2006 | 12:15 PM
IM QUIKR's Avatar
IM QUIKR
Default actual fluid level
Does anyone know where the actual fluid level is in the pan? Does it sit below in the wings or up to the pan gasket?
Old Jan 2, 2006 | 12:18 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Originally Posted by rws.1
I always check my oil ... with the engine cold so that it is always consistent.
Old Jan 2, 2006 | 01:17 PM
I too check my oil when the engine is cold. FYI, the oil consumption problem appeared mostly in manual equipped cars. Not saying it couldn't happen in an auto, but it was not as common.
Old Jan 2, 2006 | 01:21 PM
mwagne16's Avatar
mwagne16
Why would the piston rings, cylinder walls, or valves care if the there is a manual or automatic sitting behind the torque tube?
Old Jan 2, 2006 | 01:56 PM
CSDMagRed01's Avatar
CSDMagRed01
I check my oil after I have driven the car and the oil is at operating temp, I shut it off and come back out after about 5 minutes. It let's the oil drain back but the oil is still warm enough to take thermal expansion into account.
True the engine internals only respond to the revs and duration. So, the oil consumption has more to do with driving habits of the "typical" A4 driver versus a "typical" M6 driver. Chevy found more consumption if the engine was held at higher revs longer, like you might do in an M6. The A4 tends to shift the car into lower revs for better fuel consumption, so the engine may exhibit the same oil consumption if driven the same as an M6, but most didn't see those kinds of revs, so there were fewer complaints. This obviously varies with the driver. I tend to have higher consumption due to the 3.15 rear and a need for acceleration. But I've had Porsches with the same level or oil use so I don't see it as a big problem.
To Oil Level
