Daytime running lamps
Old Nov 23, 2005 | 05:03 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Default Daytime running lamps
what bulbs are used for the day time running lights and how much do they cost?
I went to pep boys and they said it was dealer only parts
Old Nov 23, 2005 | 05:36 PM
eec8059's Avatar
eec8059
4157, I believe
You can also use 3157
Old Nov 23, 2005 | 05:41 PM
DeeGee's Avatar
DeeGee
4157 NALL (amber long life)
To change the bulb turn on the headlights and back off one position to kill the lights. Unscrew the 3 small screws on the black plastic housing around the headlight. Gently pull the housing clear. Reach down around the headlight unit and release the bulb holder. It unscrews counter clockwise but it has a plastic clip which you need to squeeze to release it. Change the bulb. Reseat the bulb holder and turn until it clicks back in place. Put the plastic housing back in place making sure to locate the small plastic tab in the bracket on the headlamp cover. Replace the 3 screws and close the lights.
10 minute job.
Old Nov 23, 2005 | 09:46 PM
phils C5 vette
is that a dealer part number or an auto store.
The nose of my car will be off to repaint some damage, and thought Id replace the bulbs then while it was easy. The bulbs are 5 years old, but I figure with the nose off, it wont get much easier than that time to replace the bulbs.
Old Nov 23, 2005 | 10:50 PM
DeeGee's Avatar
DeeGee
You can get them at Walmart
To Daytime running lamps
