[Z06] Shift light
Old Nov 25, 2005 | 09:29 PM
Z06 KOS's Avatar
Z06 KOS
Originally Posted by briann510
How can a shift light not work for someone? Thats an interesting comment...
Shift light comes on..you shift...pretty simple sounding to me...
Here's a video of my Raptor shift light in action. I installed it right above eye level and its VERY bright red when it goes off. I set it at 6200 RPM to allow for reaction time.
Haven't hit the rev limiter since
Video of Raptor Shift light - Eye Level
Old Nov 25, 2005 | 09:38 PM
zo6vetteman2003's Avatar
zo6vetteman2003
Sweet!
Old Nov 25, 2005 | 09:41 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
Originally Posted by zo6vetteman2003
Here is what I found. If you access the PCM, go to the red output plug and look for PIN #10. This should be a white wire where you would attach a shift light and the other side to a 12V source. Grounding can be to any grounding point. I don't know how accurate this is, I found it online regarding a shift light installation on a 01' ZO6.
http://townhall-talk.edmunds.com/dir...w/.ef17d75/574
Scroll down alittle. #579. It isn't well written at all.
Yes, that's the wire for a after market shift light, which you can set at one rpm only. I want to find the HUD light wire, which by going into HP Tuner you can put what ever rpm you want into each of the six gears.
Robert
Old Nov 25, 2005 | 09:45 PM
Z06 KOS's Avatar
Z06 KOS
Sweet!
Here is better video of the Raptor in action. Notice the bracket mounting and how bright it is.
My buddy says it "blinds" him when it goes off and he instictively moves his left clutch leg...lol
Better video of Raptor in action - can see bracket mounting
Old Nov 25, 2005 | 09:51 PM
zo6vetteman2003
Robert
I think the reason why you can't find the HUD light wire it is a digital circuit on the HUD board.
Old Nov 25, 2005 | 09:52 PM
zo6vetteman2003
Works sweet and good kill hehe.
Old Nov 25, 2005 | 10:51 PM
JimBacus's Avatar
JimBacus
Got LAPS?
St. Jude Donor '06
Here's my blue Raptor shift light going through its start up sequence. It is bright, you won't miss it when you need to shift!
Raptor Shift Light
Old Nov 26, 2005 | 08:33 AM
zo6vetteman2003
Raptor Shift Light
Can't miss that Jim. Hey nice colored Z.
Old Nov 26, 2005 | 10:48 AM
RPOZ16's Avatar
RPOZ16
Originally Posted by Ranger
Think about your reaction time at the tree as it blinks yellow...yellow...yellow...green. You have three warnings of the impending green and yet most drivers cannot produce a consistent near perfect light.
Now imagine a single flash, to which you must react. Will your reaction time be the same every time?
Add to that, most simple shiftlights have a single rpm set point. But the engine revs progressively slower as car speed increases. The driver must adapt to that. 1-2 shift immediate on the light; 2-3 pause and shift; 3-4 pause, pause and shift. It takes a lot of practice.
Just a thought.
Ranger
I agree with Ranger. But, I don't think that many people would just be looking straight ahead and wait for the shift light to flash. If they did the reaction time would be slow. I watch the tach climb and once it crosses 6K I am waiting for the light. The HUD isn't bright enough for me (probably a function of my age )
Also, while I grew up shifting by listening to the engine for shift points (couldn't always afford a tach and most cars didn't have them) I find it difficult to believe that many people could hear the difference between 6.4K and 6.5K engine speed if that is where they were shifting. Why do most of the expensive pro tachs have shift lights? Humm, must be an advantage in some form.
Just my .02 cents, this is a fun thread.
Old Nov 26, 2005 | 11:10 AM
402Sam's Avatar
402Sam
I went with an autometer shift light from Jegs
http://www.jegs.com/webapp/wcs/store...0337&langId=-1
I mounted it on the a pillar like everyone else here has. If you cant see this light when it lights up you must be stevie wonder..
Old Nov 26, 2005 | 01:48 PM
Z06 KOS's Avatar
Z06 KOS
Indeed, I drove/raced turbo Hondas for 4 years before I got my z06. When the honda would reach redline the engine sounded like it was gonna litterally explode and thats when I shifted. But with the V8 its a constant drone compared to the screaming honda's 4 cylinder so it took some time getting used to, and had a huge learning/conditioning situation to compensate for.
Everyone told me to get used to the V8 sound and the lower fuel cutoff point, meanwhile I kept hitting the rev limiter so I was like "forget this!" and got a shift light.
Been a happy camper since
Old Nov 26, 2005 | 05:41 PM
z0quick's Avatar
z0quick
Very difficult to see the HUD shiftlight in the fast moving action at the drag strip. Plus that shift light lags the actual engine rpm.
With that in mind, you are better off either (1) getting a real shiftlight, like the Raptor, or (2) learning the rhythm of your engine's sounds, like most of us do.
Ranger
I used the stock shift light on the HUD at the track the other night and nailed every shift perfect...and that was my first time at the track with the Z (Ive had it for 1 month) and I have very little drag racing experience with manual cars..
Old Nov 26, 2005 | 08:10 PM
  #33
Ranger's Avatar
Ranger
Good to hear.
Might want to consider though that there is a difference between making good shifts (1) that miss the limiter and (2) making shifts just before the limiter. It's number (2) that yields the fastest times. If you can manage (2) using the HUD shiftlight, then you should be running between 11.9 and 12.3. If your times were in that range, please let us know.
Ranger
Old Nov 26, 2005 | 10:36 PM
  #34
Robert56@RNS
Collections Hold
We'll I can assure you that shifting a pro drag car is a whole new ball game. My father ran fuel altereds for many years and never used a shift light, just a tach. Does this mean there is no place for a shift light, no, not at all, but more for the pro guys.
I think if we look at the fast Z06 list, you'll find that the vast majority do not use a shift light. Furthermore, if you look at who is using the shift light you'll se they are not on the list. This should be a tell tale factor for going fast, as has been stated. I don't mean any disrespect to anyone using a light, if it helps you fine. I just think on our cars tring to look at the tach and trying to be aware of a shift light is less than ideal, imo. I tried all the combos and found for me, I am quicker using just the tach, and am thinking of an after market to mount on dash higher.
Robert
Old Nov 27, 2005 | 01:07 AM
  #35
JimBacus's Avatar
JimBacus
Got LAPS?
St. Jude Donor '06
Just for a little perspective, I find mine useful on a road coarse not a drag strip. Sometimes there are so many things going on with cars around you and such that the shift light can give you a gentle reminder before the rev limiter does.
Old Nov 29, 2005 | 04:10 PM
  #36
TSDuke's Avatar
TSDuke
Good lord, you guys sure are a judgemental bunch. If somebody wants to use a shift light, then use it. What's wrong with that?
Old Nov 29, 2005 | 04:33 PM
  #37
Robert56@RNS
Collections Hold
Nothing at all, just trying to point out that possibly a light may slow some down, concerning ET. I still have my raptor on my pillar gauge mount, but don't even notice it cause I do better with out.
Robert
To Shift light
Old Nov 29, 2005 | 05:00 PM
  #38
Ranger's Avatar
Ranger
If you read all the posts on the thread, there is a very good range of opinions. Most anyone who has accumulated a bunch of runs in a Z06 has had to grapple with the issue of avoiding the rev-limiter, so experiences and solutions vary. No surprise. And that is far from "judgmental."
Like just about any topic on Vettes or life...there are many opinions and the person seeking an answer must evaluate the responses and draw conclusions.
Ranger
Old Nov 29, 2005 | 06:31 PM
  #39
C6~Missle's Avatar
C6~Missle
Robert
I like the idea of having an rpm range for each gear... I find the HUD shift light to be too small... it doesn't stand out enough... I use the tach and engine sounds...
Old Nov 30, 2005 | 12:45 AM
  #40
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
I have a raptor here sitting at the house waitng for my car to get back from the HC swap. My 01 does not have a hud (early build, May 20th...) so I had to peak at the tach. I am not in the fast crowd so I need all the help I can get I have been trying to shift right @ redline (7K now) to help get into a better spot on the next gear. I find with 342s the 3rd to 4th is a bit long and I need to be just about to kiss it beofe the shift. Last week at the track I kissed it in 3rd even though I was @ 6900 Too bad as the GN beside me well, it was beside me not in back of me!
Dave
PS Tucker you find what you where looking for earlier brother? Hope the shop I called you from can help you out. PLease let me know if I can help out.
