[Z06] Anybody know what this is???
Old Nov 25, 2005 | 04:06 PM
bobgodd's Avatar
bobgodd
Default Anybody know what this is???
I'm trying to figure out what this is, it was on the car when i bought it. the guy i bought it from says the only mods it has is a halltech CAI, upgraded injectors (why im not sure) and some kind if new(?) MAF.
anyone know anything about this?
thanks
rob
Old Nov 25, 2005 | 04:20 PM
MikeNMaxZO6's Avatar
MikeNMaxZO6
Never seen that before...sorry!
Old Nov 25, 2005 | 04:25 PM
bobby777's Avatar
bobby777
I see Halltech tric system with 2 adj. *****-
Old Nov 25, 2005 | 04:28 PM
bobby777's Avatar
bobby777
I see a box with halltech tric system on it with 2 adj. ***** Follow the wires and see what it adjusts-
Old Nov 25, 2005 | 04:48 PM
bobgodd's Avatar
bobgodd
cant exactly follow the wires, they are kinda burried in there.
Old Nov 25, 2005 | 05:11 PM
Fast98's Avatar
Fast98
Old Nov 25, 2005 | 05:34 PM
Z28TOZO6's Avatar
Z28TOZO6
that looks like a high low cutoff for NOS. Ask ConnecticuT about it.
Old Nov 25, 2005 | 07:59 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Send a PM to Jim Hall, (owner of Halltech) he is a very active member here lately. You will see him alot in the C6 sections these days.
zo6vetteman2003's Avatar
zo6vetteman2003
thanks
rob
It looks like a MAF Translator to change and adjust your injector pulse width. I had one on my 99' FRC. They work pretty sweet by tricking your PCM into thinking you are running rich or lean so it adds fuel or takes it away. If you have large injectors, this will help lean them out until you have mods. to support them.
Old Nov 25, 2005 | 08:05 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Ask Jim Hall @ Halltech
jim@CorvetteC5.com
Old Nov 25, 2005 | 09:02 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
maf translator gets the nod, w/ all the tuning out there you would think this would be gone by now
Old Nov 25, 2005 | 11:21 PM
bobgodd's Avatar
bobgodd
i would have posted a pic of the ***** but there arent any markings or any labeling of any kind as to what the ***** are for. i guess if i get my car tuned i should go to jim hall?
Old Nov 25, 2005 | 11:49 PM
itsmeek's Avatar
itsmeek
maf translator common w/the injector "mod"
Old Nov 26, 2005 | 12:05 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its kind of worthless without knowing what your fuel trims are! If you have a wide band O2 reader, and some tuning software then you could adjust the MAF so that the air flow computations that it provides the PCM are correct.
BC
Old Nov 26, 2005 | 11:25 AM
southerncarparts's Avatar
southerncarparts
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
Old Nov 26, 2005 | 11:31 AM
zo6vetteman2003
LOL! There still is the other MAF Translator out there that you can use with older C5's. I think they may make an adapter for later C5's with the newer MAF sensors I think 4 wire instead of 3.
Old Nov 26, 2005 | 08:52 PM
bobgodd's Avatar
bobgodd
so is it worth anything or should i have it removed?
To Anybody know what this is???
