[Z06] Brake dust
Old Nov 26, 2005 | 05:46 PM
z0quick's Avatar
z0quick
Default Brake dust
tried to search for this but was unsuccessful...
I got my Z about a month ago and have noticed the brake dust is insane! After washing my wheels about 100 miles later they are black. I owned an FBody before this car which had chrome ZR1 wheels and they didnt get this dirty so quickly...
- Is it that my pads are ****ty? I dont know what pads are on there bc I bought the car used. What kind of pads should I get? Hawke?
- Also, while Im at it, what seem to be the most popular drilled/slotted rotors for this car?
thanks
Old Nov 26, 2005 | 05:58 PM
2MchFun's Avatar
2MchFun
Lots of guys switch to ceramic brake pads. They are not quite as good as the stock pads, but are a LOT less dusty.
As far as rotors go, Baer Eradispeeds seem very popular, but are not cheap. If you plan to track your car much, Hawke pads are good, avoid drilled rotors - they crack
Old Nov 26, 2005 | 06:00 PM
DWS'03Z's Avatar
DWS'03Z
the OEM pads were designed for track use and dust heavily......I switched to GM ceramic pads, as they are fine for street driving.....based on others' comments, though, I would not use ceramics on the track....
Old Nov 26, 2005 | 06:03 PM
z0quick's Avatar
z0quick
good info guys, looks like I might just need to switch to ceramic then...
You say avoid drilled rotors, but Eradispeeds are drilled though
Old Nov 26, 2005 | 06:06 PM
2MchFun's Avatar
2MchFun
Drilled are OK for street use.
Old Nov 26, 2005 | 06:29 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
I use ceramics on the fronts and the dust has been reduced 95%...For non-track (roadracing) street driving, they're fine..
Old Nov 26, 2005 | 06:31 PM
z0quick's Avatar
z0quick
You guys have a part#? Where is the best place to get em? Even my rear wheels get puked on..
Old Nov 26, 2005 | 06:35 PM
04Z16's Avatar
04Z16
CI 3-4-5-6-7-8-9-10 Veteran
Gene at Fred Beans had a special for the front and rears. They are a supporting vendor and great to deal with. GM Parts Direct also has them but I think Gene has a better deal. Look on the side post for the link to both places.
I put the ceramic on mine at about 200 miles and not a bit of problem or dust.
EDIT: The part numbers are
Front 88909667 $57.84
Rear 88909668 $36.42
These prices are off the www.gmpartsdirect.com web site. I think Gene at Fred Beans had them for a better price and shipping.
Old Nov 26, 2005 | 07:20 PM
Terry Humiston's Avatar
Terry Humiston
From Fred Beans I did the full setup and it looks great with little dust
||--Genuine GM Ceramic Brake Pads--||
88909667 – Front ceramic pad kit
88909668 – Rear ceramic pad kit
Both front and rear ceramic pad kits 113.53 shipped!
AC Delco Performance Drilled/Slotted
88926731 – RF rotor
88926732 – LF rotor
88926733 – RR rotor
88926734 – LR rotor
Front and rear rotor sets 247.10 shipped
Old Nov 26, 2005 | 08:09 PM
why_ask_why's Avatar
why_ask_why
another fan of the ceramic swap...did it a little over a month ago and zero dusting now
Old Nov 27, 2005 | 10:36 PM
longdaddy's Avatar
longdaddy
I put 3 coats of wax on the wheels. I wipe the dust off once every two weeks on the front wheels and once a month on rears, after washing the car. It not too bad, I keep them pretty clean and it is not that much work (well, except for the intial waxing). Don't want to give up braking perf so I live with it.
Old Nov 27, 2005 | 11:04 PM
z0quick's Avatar
z0quick
Ended up just gettin the ceramics from Beans...good price ~ $110 shipped
thanks
Old Nov 28, 2005 | 12:02 AM
slong's Avatar
slong
I did, and it was a world of differance. Hardly noticed the change.
Old Nov 28, 2005 | 01:49 AM
striper's Avatar
striper
Another satisfied ceramic pad user. Got them and drilled/slotted rotors from Fitchner Chevy for $300 plus shipping.
Old Nov 28, 2005 | 02:29 AM
Z28STYLE23's Avatar
Z28STYLE23
those that have done the ceramic change how much did braking power reduce??
Old Nov 28, 2005 | 07:21 AM
why_ask_why
virtually nil for street driving imo...the shop I go to used some higher end aftermarket ceramics on my car though...not sure if that makes any dif
Old Nov 28, 2005 | 10:03 AM
slong's Avatar
slong
but I went with the GM product: 88909667 – Front ceramic pad kit & 88909668 – Rear ceramic pad kit.
To Brake dust
Old Nov 28, 2005 | 10:44 AM
Z06Doug's Avatar
Z06Doug
You lose a little bit of braking power, but likely not enough to be noticable. If you want to compare it go stand on your brakes with the stock pads and you'll more often than not kick on the ABS. I have yet to kick the ABS on with the ceramics.
They are still more than adequate for street driving.
Old Nov 28, 2005 | 01:24 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
Another common pad is the Hawk Street Pads.
http://www.corvettegarage.com/index....cturers_id=103
Old Nov 28, 2005 | 02:50 PM
Chris Stewart's Avatar
Chris Stewart
I got mine from Autozone and they are great! Another benefit with ceramic pads is they don't squeak like the stock pads. The stock pads are so embarassing in slow traffic with light brakes they squeal like a pig. Not anymore!
