[Z06] Brake dust
Old Nov 28, 2005 | 08:02 PM
pianoprodigy's Avatar
pianoprodigy
St. Jude Donor '12
This might be a dumb question, but if the car is on the lift, do the wheels need to come off to install the new pads? I'm annoyed by the brake dust (despite the Wheel Wax which helps) and the squeal.
Old Nov 28, 2005 | 08:43 PM
Chris Stewart's Avatar
Chris Stewart
Yes the wheels need to come off. Re-torque to 100 ft-lbs.
Old Nov 28, 2005 | 10:52 PM
Fluid Flight's Avatar
Fluid Flight
are you saying ceramics provide less brake performance?
Old Nov 29, 2005 | 07:26 AM
why_ask_why's Avatar
why_ask_why
that's the word I've gotten since joining here...personally I have seen zero difference
Old Nov 29, 2005 | 08:39 AM
DWS'03Z's Avatar
DWS'03Z
according to those that have tried ceramics on road courses, repeated hard braking will result in diminished braking capability......ceramics for street use is fine
Old Nov 30, 2005 | 07:29 PM
J Z06's Avatar
J Z06
I am not sure what I will do when it comes time to do brakes.
I have access to any AC DELCO part working for a parts store.
Akebono's are supposed to be good. I'd dispose of the rotors and put fresh one's on. No sense in compromising. They're not that expensive.
Old Nov 30, 2005 | 07:47 PM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
Or at least have them turned down.
Old Nov 30, 2005 | 08:38 PM
J Z06's Avatar
J Z06
Turning them takes away material, making them thinner and easier to warp(less heat dissipation(sp?)) therefore....fresh rotors will go on. If my originals are in good condition when I replace them, I'll sell them on here.
Old Dec 3, 2005 | 01:14 AM
silver_z06's Avatar
silver_z06
Originally Posted by 2MchFun
Lots of guys switch to ceramic brake pads. They are not quite as good as the stock pads, but are a LOT less dusty.
As far as rotors go, Baer Eradispeeds seem very popular, but are not cheap. If you plan to track your car much, Hawke pads are good, avoid drilled rotors - they crack
when u say "not quite as good as the stock pads" do you mean that the stock pads brake better than the ceramic brake pads???
Old Dec 6, 2005 | 11:35 PM
Crocodile Dave's Avatar
Crocodile Dave
I enjoy praying on my knees every Sunday morning to my alloy gods- (there are 4 of them), with toilet bowl brush in hand.
Old Dec 8, 2005 | 10:50 PM
DJMRTS's Avatar
DJMRTS
How does the GM ceramic pads work with the Baer slotted/drilled Eradispeed rotors. I'm using Hawk Streets right now but they are too noisey and cause too much dust.
