[Z06] Dyno question?
The reason I'm asking is because I have an '02 Z06 and once the car gets to 5400 rpm's the car peaks and the graph rolls off similar to several ls1/ls2 graphs I've seen. A stock or near stock Z06 peaks around 6200 rpms.
I have replaced valve springs and pushrods thinking it could be valve float but no luck. I have also tried replacing the MAF while on the dyno, no luck there either. My A/F is almost perfect at 13.0. I am not the original owner of the car so I'm beginning to wonder if it had an aftermarket cam at some point and was replaced with whatever they could find.
That seems a little far-fetched since everything was dead stock on the car all the way down to stock plugs. Well with the exception of a Halltech stinger. Any other suggestion or ideas on anything I could check before getting into the motor. Oh, there is no knock retard in any part of the RPM's and the car is tuned. Nothing shows up saying that it could be mechanical.
I took the car to the track last weekend and it ran a 7.96 right at 92 mph so it seems to be fine comparing to other Z06's... Just not on the dyno?? This run was made on F1 SC's with 25k on them. My 60 ft. was a 2.01 and lots of tire spin going in to second and some going into third.
Your 1/8 mile times equate to approx. 12.2X quarter in my drag log, which bests the Chevy spec. So it's very unlikely that the engine is down on power.
Ranger
and recently i dynoed my 01-with rear tires with 7k on them and did 373 rwh 352 tq-and my mods are limited the usual intake and cat back stuff.
At < 8 sec 1/8 miles and 92mph, your car runs strong and you are apparently a decent driver. Kind of odd about the dyno though. I really put very little stock in dynos except for "relative" verification of changes.
Thanks again.
