CAGS Skip Shift Bypass question?
Old Nov 27, 2005 | 10:58 AM
craig04c5's Avatar
craig04c5
Originally Posted by madeouttaglass
I was forced into 4th twice while turning with traffic in an intersection. There was no room in front of me to give it enough gas to rev past the GACS. Both times made me look like I couldn't drive a stick. Pay the $20 and fogetaboutit.
This happened to me also, almost had an accident so I decided the Skip Shift was a must. If he has to ask though I guess he doesn't need it.
Old Nov 27, 2005 | 11:44 AM
rc51racer's Avatar
rc51racer
Actually I like CAGS. When I am joy riding around town in the economy mood I use CAGS all the time. I think I shift at about 20MPH from 1st to 4th. When I want to step into it or enjoy the revs I just shift it when I want but then of course CAGS is not an issue then. CAGS did fool me a few times before I new what it was. I remember thinking to myself I know I was in 1st gear but somehow I ended up in 4th. To each his own I guess.
Old Nov 27, 2005 | 12:45 PM
scottydog's Avatar
scottydog
I put in the cags mod, then ended up taking it out. Better gas mileage, fewer shifts in slow traffic.
Old Nov 27, 2005 | 12:53 PM
WWK888's Avatar
WWK888
You do not need the CAGS if you want to shift 1-4, why not leave the CAGS Eliminator installed so you at least have the option????? You make it sound like you can't shift 1-4 without the CAGS.
Old Nov 27, 2005 | 01:05 PM
craig04c5's Avatar
craig04c5
Old Nov 27, 2005 | 01:18 PM
DPG's Avatar
DPG
St. Jude Donor '06
yea its worth it. Heavy traffic is the only reason i have to say.
Old Nov 27, 2005 | 01:22 PM
vermjpv's Avatar
vermjpv
Now a CTS-V Owner
CI 5-6-7 & 9 Veteran
St. Jude Donor '05-'06-'07-'08
The easiest and cheapest mod on a 6SPD. Right next to CLB for the 6SPD!!!
Old Nov 27, 2005 | 01:25 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I don't have it and wouldn't spend $1 on it! I drive the car and shift a higher RPM's (just the way Zora intended! ) and it almost never comes up. Just drive through it! Just because the lamp illuminates doesn't mean you HAVE to shift!
Old Nov 27, 2005 | 01:42 PM
convertible lover's Avatar
convertible lover
In my case the sensor went out and turn the check engine light on. I was told it was over $100 for a new one. So I told the mechanic about the cags for $20, he had never heard about them. I only knew because of this forum. But after the install Check engine light has not come on, not because of that reason anyway. So which way would have gone in that case? I think it is well worth the money.
Old Nov 29, 2005 | 03:38 PM
DaBeast's Avatar
DaBeast
so did any one make there own home made cags eliminator???
i know someone has used resistors to make it work
Old Nov 29, 2005 | 05:22 PM
sandmanusd's Avatar
sandmanusd
Originally Posted by love my car
Hey folks ive been wanting to do this mod,is it as easy as its made out to be?I did the CLB and it took me a little longer than everyone said.I hate that every once in awhile im trying to fight the car into 2nd.
It really is... the "hardest" part is getting under your car... but if you have rhino ramps, that makes it easy (which I bought specifically to do this mod)... then its like unplugging a toaster and plugging it back in...
like I said, the longest and hardest part of the mod is getting the *** end into the air to do it...
Old Nov 29, 2005 | 10:47 PM
H-T's Avatar
H-T
Originally Posted by WKMCD
You can even get the light edited out so you can forget it was ever there.
How do you eliminate the shift light from ever coming on again?
Old Nov 29, 2005 | 11:56 PM
  #33
minytrker's Avatar
minytrker
Yes I have made a few, well not really made but installed the resistor on a few. You just need a 2.2K ohm .5 watt Radio Shack resistor, unplug the plug, install the resistor, wrap in electrical tape and zip the plug up and out of the way.
Old Nov 29, 2005 | 11:58 PM
  #34
minytrker's Avatar
minytrker
That has to be turned off with a program like ls1 edit, hp tuners or something like that. Once that is done you won't need to bypass CAGS anymore.
Old Nov 30, 2005 | 04:18 AM
  #35
DaBeast's Avatar
DaBeast
where do we put the resistor?
Old Nov 30, 2005 | 10:35 AM
  #36
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
bend the resistor like a U, and put each end in the male connector of the electrical input on the transmission(back of car). Wrap electrical tape around the male and female ends, and take a tie strap and tie it out of the way. Take your left over $19 and go to the strip club
Old Nov 30, 2005 | 11:26 AM
  #37
zonsolo's Avatar
zonsolo
I haven't done it either and probably won't bother. It has never come up when I've been behind the wheel. I've had it happen to others driving it, but I can't even seem to make it kick in when I try.
To CAGS Skip Shift Bypass question?
Old Nov 30, 2005 | 01:10 PM
  #38
SavPrato's Avatar
SavPrato
Old Nov 30, 2005 | 06:20 PM
  #39
DaBeast's Avatar
DaBeast
i will go ahead and do that right now then
thanks man
Old Nov 30, 2005 | 08:03 PM
  #40
wolfmd's Avatar
wolfmd
Originally Posted by Glennm27
It proved you were shifting too soon....
