CAGS Skip Shift Bypass question?
Old Nov 26, 2005 | 07:34 PM
motorpsycho98vette's Avatar
motorpsycho98vette
Default CAGS Skip Shift Bypass question?
Anyone install the skip shift bypass adaptor, what does it do? Is this needed?
Old Nov 26, 2005 | 07:37 PM
C5naples's Avatar
C5naples
I installed it. Needed it in traffic conditions. I really like it, the skip shift really bothered the hell out of me.
Old Nov 26, 2005 | 07:43 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
Originally Posted by motorpsycho98vette
Anyone install the skip shift bypass adaptor? Is this needed?
No, it just keeps the connection clean. I waisted my money on one.
Just unplug it if you want.
Old Nov 26, 2005 | 07:48 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
I was forced into 4th twice while turning with traffic in an intersection. There was no room in front of me to give it enough gas to rev past the GACS. Both times made me look like I couldn't drive a stick. Pay the $20 and fogetaboutit.
Old Nov 26, 2005 | 07:55 PM
BobbyG's Avatar
BobbyG
Bought mine from Mid America for about $20 if I remember correctly. I couldn't understand why anyone would "design in" such a nuisance, it's also dangerous!
Bob
Old Nov 26, 2005 | 07:57 PM
Goonie's Avatar
Goonie
you can always add more gas and then shift into 2nd... works for me... the light does bother me cause it looks like the check engine light
Old Nov 26, 2005 | 09:19 PM
H-T's Avatar
H-T
That was the first mod I did. I could not stand it forcing me to shift from 1-to-4 in heavy traffic. Just buy the $20 kit, back the car up onto your rhino ramps and 15-minutes later, no more shift worries!
Here is a link for you on this forum:
https://www.corvetteforum.com/techti...D=12&TopicID=6
Old Nov 26, 2005 | 10:06 PM
edensknight's Avatar
edensknight
Old Nov 26, 2005 | 10:27 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
It proved you were shifting too soon....
Old Nov 26, 2005 | 10:40 PM
Is it needed - no. But it sure makes driving the car a whole lot more fun. It will disable the forced 1-4 shift under certain driving conditions - you will have total control over what gear you shift into. For $20 and about 5 minutes of install time, it's well worth the price.
Old Nov 27, 2005 | 01:54 AM
01QuickSilver's Avatar
01QuickSilver
Well Said!!
Old Nov 27, 2005 | 02:12 AM
spiderman's Avatar
spiderman
There was a post on this forum that showed you how to do the defeat. Radio shack sells the transistors in a (4) pak for $.99. The caps for $.99 and a little electrical tape and your done. AND $18 bucks ahead!!! I've done (2) of my vettes and (2) friends whith NO issues to date.
Old Nov 27, 2005 | 03:23 AM
WWK888's Avatar
WWK888
Bob
It was designed so we don't have to pay a gas guzzler tax on top of our MSRP.
Old Nov 27, 2005 | 03:29 AM
DaBeast's Avatar
DaBeast
what resistors did u use?
can you give me some info on this?
i want to do this as well thanks
Old Nov 27, 2005 | 06:59 AM
Cajun99's Avatar
Cajun99
Even though the skip-shift helps Chevy achieve their CAFE numbers I'm not going to have a manual shifted car dictate to me when I can or cannot shift
Second mod I bought years ago right behind a CLB. Could care less about saving pennies after what I've pumped into this car in the way of mods so I bought a "premade" one for around $20.
Old Nov 27, 2005 | 07:06 AM
love my car's Avatar
love my car
Hey folks ive been wanting to do this mod,is it as easy as its made out to be?I did the CLB and it took me a little longer than everyone said.I hate that every once in awhile im trying to fight the car into 2nd.
Old Nov 27, 2005 | 07:20 AM
WKMCD's Avatar
WKMCD
You can even get the light edited out so you can forget it was ever there.
To CAGS Skip Shift Bypass question?
Old Nov 27, 2005 | 07:37 AM
Cajun99's Avatar
Cajun99
YES!! It IS as easy as it's made out to be. Once you get under the car if it takes you longer than five minutes to install the CAGS eliminator then you're just plain messin' around
Here's how to do it...
http://97vette.com/howto/cags/index.html
Old Nov 27, 2005 | 09:07 AM
rws.1's Avatar
rws.1
The 1 to 4 shift only cuts in if you around around 12% of throttle and at 2000 rpm in 1st( #'s approx)
So if you have the throttle open more... it won't kick in.
It seems only to happen when you ar ein heavy ,slow moving traffic and can't drive at the speed nor accelerate the way the Vette was designed to drive.... ie.... it is a pain in the butt that re-appears when you least want it.
The skip shift (CAGS) eliminator is well worth the $20, 20 minutes it takes to install.... think of it as skipping one McDonalds meal to avoid a lifetime of annoying inconvenience.....
Old Nov 27, 2005 | 09:29 AM
cuspid's Avatar
cuspid
The one I bought was defective. I took it apart and there was no resistor in it. It had two wires running into a plug of silicone.
