Brake Replacement
Old Nov 27, 2005 | 09:14 AM
Big Daddy G's Avatar
Big Daddy G
Default Brake Replacement
Can you all give me an idea at what mileage you had to have your brakes replaced as I am at 53k and going strong.
Old Nov 27, 2005 | 09:40 AM
AU N EGL's Avatar
AU N EGL
It depends on how your drive and brake. If normal street driving your fine. Look at your brake pads or check your owners manual. Change your pads at 30%. and IMHO flush you brake fluid every 2 years in all your vehicals.
Brake fluid looses its abilty as it become saturated with water. Water satureation is 4% in brake fluid, which under normal use is 6 to 18 months. Saturated brake fluid can take up to 25% longer but in most cases 10% longer to stop your car. If you have an emergancy situation even longer to stop.
But then again I am kinda particular on brakes .
HTH
Old Nov 27, 2005 | 11:47 AM
b98's Avatar
b98
Brakes are cheeper than body work. 24000 miles for me.
Old Nov 27, 2005 | 01:32 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Brakes? I thought those slotted and drilled things I have were part of the wheel! I don't use 'em - that's what the horn is for!
J/K! Depends on the type of driving you do - all highway driving is a lot easier on the brakes than city driving. Also - competition driving has a tendency to eat up the pads, too.
Old Nov 27, 2005 | 02:23 PM
Lancer033's Avatar
Lancer033
you mean that most people don't have to replace their brakes every other weekend?????
on a serious note: my stock pads had 24K before I swapped them out, they've got about half their life left in them, I've still got them around as a get home/emergency set
Old Nov 27, 2005 | 03:42 PM
edensknight's Avatar
edensknight
Brakes are definitely cheaper than autobody repair.
Old Nov 27, 2005 | 03:43 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Bingo !
Old Nov 28, 2005 | 05:11 PM
Big Daddy G
tks guys
Old Nov 28, 2005 | 05:23 PM
diyguy's Avatar
diyguy
Replace them under TWO conditions:
1. When you get tired of seeing brake dust cover your wheels. OR,
2. When you no longer see brake dust on your wheels (and haven't changed to ceramic or Hawk pads yet.)
To Brake Replacement
