Absolutely awesome. I bet you could do well with something like this but I assume because of the low volume, they would have to be manually made- sounds tedious and expensive!!!
You can see in the photos below how I cut out the HVAC trim and relocated it lower down. The Bondo you see is before final sanding. Most of the fill work was done using ABS and Oakley ABS cement. (available at Lowes or Home Depot) The Bondo should be used only for hiding slight imperfections.
You mention (above) using ABS and ABS Cement on the fill work. Do you mean that Lowes or Home Depot stocks an ABS fill paste similar to bondo or were you meaning that you used pieces of the ABS trim you cut out to piece together the gaps, then used bondo to fill the seams?
Your work looks great.
Thanks.
I had an old pillar gauge pod made of ABS laying around the shop, so I cut that up for pieces to fill in the major gaps. There really is a minimum of Bondo in the whole project. It's mostly pieces of ABS, molded together with Oatley ABS Cement. This stuff is so thick that you can literally use it to fill voids and bridge gaps. It's much easier than trying to mix up your own sludge using ABS shavings and MEK or Acetone.
To answer everyone elses questions...
These things are much too time consuming to make any money at it. You'd have to charge a fortune for them. It's much easier just to show everyone how it's done and let them do their own. It's really not that hard, just time consuming...
