Another Stock battery bites it.
Old Nov 28, 2005 | 11:26 PM
unstressed's Avatar
unstressed
Default Another Stock battery bites it.
3.5 years old. Car is an 02.
Left me stranded at night after work.
Drove fine at lunch time, no indication of problems at all. Came out at night, and it wouldn't even unlock the door.
It measured 6 volts.
Nothing was left on, it just died.
Installed a new Diehard Gold and I'm off again.
Old Nov 29, 2005 | 12:03 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
I installed a new DH Gold about 4 mos. ago. They are good batteries w/ a better warranty than Optima...
Old Nov 29, 2005 | 12:16 AM
unstressed's Avatar
unstressed
Yeah I was plesantly suprised....3 year free replacement, then a decent pro rating for a long time...
Old Nov 29, 2005 | 12:49 AM
Rob 99's Avatar
Rob 99
I'm "Apache" a psycho dog
my stocker sat for two weeks and i tried to start it today and was completly dead,thought it would last longer than that before going completly dead so i charged it with a 10amp charge.
It started and now have the 1.5amp trickle on it but the charger is indicating 'trouble' wont take a full charge, it's stored in the garage for the winter and will install a new battery come springtime will resesrch the DH Gold amongst others
Old Nov 29, 2005 | 12:52 AM
Yibbutkeen's Avatar
Yibbutkeen
How long do the dh golds last? I've got a pair of 10 year old red tops in my hummer - best batteries ever.
Old Nov 29, 2005 | 07:07 AM
BiggieBoy's Avatar
BiggieBoy
Man, I sure would like to know your secret. I went thru 3 Red Tops in a little more than 4 years (dead cell, dead cell, dead cell). I wouldn't have another Red Top it you gave it to me for free. I'm happy they work for you. Good luck...
Old Nov 29, 2005 | 07:12 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
I understand that the long term view on Optimas have been that they are the best around, but I also understand that there was a recent blip in their quality and overall performance. Not sure why. I have an Optima I but in a year and 1/2 ago and no problems.
Old Nov 29, 2005 | 08:55 AM
DeeGee's Avatar
DeeGee
Good plan. Make sure you pull it out of the car. The computer is under the battery tray. If it leaks....... There are also some wierd symptoms when a battery dies.
I've had the instant and total failure and a "leaker". Luckily the laeker was in the Camaro and I caught it before it did any damage.
I did a poll a short while ago. As one member pointed out, it wasn't very scientific. It did, however, flag up the fact that there are a lot of problem AC Delco batteries out there.
Old Nov 29, 2005 | 11:59 AM
gr8corvette's Avatar
gr8corvette
Gr8Corvette
Mine died the same way, worked great when I turned it off, then nothing when I went to use it the next morning.
I went to dealer, they wanted too much. My service advisor (who I do trust) told me I could get a better deal elsewhere. I went to Sears, they told me they would not replace the battery unless they tested it first. They wanted to charge me $25 to test a battery that I knew was bad!
I then went to Advance Auto parts. They actually came outside and replaced the battery for me! This was three years ago and the battery is still working for the guy I sold my first C5 to.
Old Nov 29, 2005 | 01:17 PM
Funny how batteries can just all of a sudden die on you. Hope the DieHard lasts for a long time.
Old Nov 29, 2005 | 01:24 PM
vertlove's Avatar
vertlove
I take it you repalced stock battery with a 10 year old one ? Since Hummers haven't been around that long.
Old Nov 29, 2005 | 01:25 PM
matt24's Avatar
matt24
Stock batteries red top all the way!
Old Nov 29, 2005 | 04:05 PM
Z0SLIK's Avatar
Z0SLIK
Yep, started on a trip last year, got there, stopped to eat, then dead!!
No warning!
Old Nov 29, 2005 | 04:27 PM
z16kalel's Avatar
z16kalel
Just be happy it's not a new Vette with the DBS.
Old Nov 29, 2005 | 06:55 PM
wolfmd's Avatar
wolfmd
That's a real bummer Mike. Hope it didn't leave you stranded somewhere.
Old Nov 29, 2005 | 08:15 PM
edensknight's Avatar
edensknight
My horrible o.e. battery died, left me stranded, AND, was not even rechargeable (would not hold a charge). Replaced the P.O.S. culprit with a red top optima, and, have been pleasantly trouble free for over three years.
Old Nov 29, 2005 | 08:46 PM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
Typical, typical. The ACDelco AGM batteries are known for sudden death. They'll work fine in the morning, but be completely dead at lunchtime. They became so unreliable, GM stopped using them after the '03 model year.
Now if you are going with a regular lead acid battery with side terminals, be very cautious about acid leaks. They've fried the wires and electronics directly under the battery of many vettes.
To Another Stock battery bites it.
Old Nov 29, 2005 | 11:21 PM
H-T's Avatar
H-T
Check this:
http://www.4x44u.com/pub/k2/hummer/humhisty.htm
July 1992 - First civilian Hummer delivered
August 1992 - Volume production of civilian Hummer begins
October 1992 - National introduction of civilian Hummer
January 1995 - First gas-powered Hummer introduced at North American International Auto Show
Old Nov 30, 2005 | 09:54 PM
RonJ's Avatar
RonJ
My 01 battery died just like that .... no warning.
Got a boost, drove it home, wouldn't accept a charge at all. I'm guessing a high resistance or open circuit in the battery. like a bad cell strap or something.
Walmart and an Optima Red Top was the answer!
RonJ ...
Old Nov 30, 2005 | 10:23 PM
mwagne16's Avatar
mwagne16
Default Pushing my luck?
My '00 still has the original one in it. I've just started to notice some strange things; DIC resets on it's own. Lights dim a bit at idle. Time to shop for a new one!!
