Jack Problem
Nov 29, 2005 | 12:54 PM
Jack Problem
i can't jack my car high enough to put the stands under,but if i remove the saddle they fit.can i put the car on the stands only. thanks
Nov 29, 2005 | 01:00 PM
Get a jack that will lift higher, or place your jack on a 2x10 lying flat on the floor and that will give you another 1 and a half inches higher. or get a set of Rhino Ramps. Never take the saddles off the stands.
Nov 29, 2005 | 01:02 PM
yup, put some wood between the jack and your car.
Not a great idea. Those saddles help the car to stay in place should there be some movement of the car on the stands. Try driving up on a "2-by" board first. That will give you 1.5 inches more to work with.
Nov 29, 2005 | 01:03 PM
Or........get this guy to help you out!!!!
Nov 29, 2005 | 01:17 PM
thanks guys i'll try the wood.
Nov 29, 2005 | 03:24 PM
Quote:
I don't think driving the car onto the wood will help your problem.
Nov 29, 2005 | 06:05 PM
not unless you next put a plank under the jack to give it extra lift height as well.....
Nov 29, 2005 | 06:33 PM
St. Jude Donor '06-'07
Let me say that if I've ever said anything that was out of line or to anger you in any way, please accept my most sincerest apology.
You DA MAN!!!
Bob
