[Z06] The lightest battery?
http://www.batterymart.com/c-odyssey.html
GUSTO
GUSTO
6 pounds Holy batteries batman,Except everything looks like they are for atv's and such
Had me going for a minute
Kirk
Batteries
13 lbs --- Odyssey/Dynabatt/Hawker racing battery --- Source
13.5 lbs --- Genesis G16EP, LWH=7.15x3.01x6.65, CC=280 --- Source
15 lbs --- PC 680, LWH=7.27x3.12x6.67, CC=280 --- Source
23 lbs --- SVR SVR28-12, LWH=6.88x6.50x4.88 --- Source
23 lbs --- Genesis G26EP, LWH=6.57x6.92x4.96, CC=470 --- Source
26 lbs --- Odyssey PC 925, LWH=6.69x7.05x5.04, CC=470 --- Source
26 lbs --- SVR SVR33-12, LWH=7.75x5.00x7.25, CC=500 --- Source
26 lbs --- Optima Yellow Top 51, LWH=9.25x5.00x9.00, CC=500 --- Source
32.8 lbs --- AC Delco 75P-7YR, LWH=9.50x7.10x7.30, CC=550 --- Source
32.9 lbs --- Genesis G42EP, LWH=7.78x6.53x6.72, CC=630 --- Source
35.4 lbs --- Odyssey PC 1200, LWH=7.87x6.66x7.55, CC=630 --- Source
33.1 lbs --- Optima Red Top 75/35, LWH=9.31x6.81x7.63, CC=650 --- Source
37.7 lbs --- AC Delco 34P-7YR, LWH=10.3x6.80x7.80, CC=650 --- Source
36 lbs --- Exide Select Orbital 75, LWH=9.00x7.00x7.44, CC=690 --- Source
38.8 lbs --- Optima Red Top 34/78, LWH=10.0x6.88x7.81, CC=750 --- Source
38 lbs --- Exide Select Orbital 78, LWH=10.1x7.00x8.1, CC=770 --- Source
45.6 lbs --- AC Delco 65P-7YR, LWH=11.9x7.50x7.60, CC=800 --- Source
57 lbs --- SVR SVR80-12, LWH=10.6x6.50x6.25, CC=800 --- Source
58.7 lbs --- Odyssey PC 1700, LWH=13.02x6.62x7.68, CC=930 --- Source
Batteries
I though the yellow top was a bigger battery but it weight less?
Edit : I guess it matters which yellow top you choose
http://www.optimabatteries.com/publi...cal_specs.html
Some are alot heavier
Batteries
Batteries
Takes the weight of the battery from the front, and adds it to the rear well, where it'll actually benefit traction.
Just a thought.
Just a thought.
nevermind, found it. took me a second to realize LPE was lingenfelter.
http://www.lingenfelter.com/Merchant...Category_Code=
I'll have to add this to the wish list. Probably too late for this Christmas.
Call Maxwell Church of Accurate Technologies (Supporting Vendor) @ (248) 848-9200 x131 Customer Service is INCREDIBLE.
- Max
