Cool Flex Hose Install Question
Old Dec 1, 2005 | 09:02 PM
KARSC5's Avatar
KARSC5
Default Cool Flex Hose Install Question
I just finished installing my cool flex hose and the coupler on the radiator side of the hose is kind of large and holding up the top radiator support/shroud from fitting correctly. The top radiator support does go on, but I had to force it. Did you have to trim the support so it fits better? Or is it Ok the way it is?
Old Dec 1, 2005 | 09:28 PM
iceburgh's Avatar
iceburgh
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05-'06-'07-'10
either..... I left mine alone and tighten the bolts down just enough that you dont crack the shroud.
It should come with in abouy 1/4 inch
Old Dec 1, 2005 | 10:51 PM
KARSC5's Avatar
KARSC5
Thanks!! Go Pens!!!
Old Dec 2, 2005 | 06:38 AM
wrustywrench's Avatar
wrustywrench
geez,, do it right,, trim the shroud ......
Old Dec 2, 2005 | 07:28 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Can't be a big deal.
Also, KARSC5. can you post some pics of the install? Thnx
Old Dec 2, 2005 | 08:38 AM
iceburgh's Avatar
iceburgh
I think you will find this looks worse..... I did both and was not happy with trimming.
As you can see in this picture WITHOUT being trimmed you cant see it
Old Dec 2, 2005 | 09:22 AM
wrustywrench
Ok,, Me Bad,, Dont Trim It....sorry...
Old Dec 3, 2005 | 10:32 PM
KARSC5's Avatar
KARSC5
Jim, I was thinking of triming/sanding it with a 2" drum sander, just enough to relieve some of the spring in the shroud and to get it off the coupler.
To Cool Flex Hose Install Question
