TPS Question...
Old Dec 2, 2005 | 10:52 PM
Batmbl's Avatar
Batmbl
Default TPS Question...
What sort of signs does one get that might make one suspicious of faulty tire pressure sensors?
Old Dec 2, 2005 | 10:54 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
if your tire is flat, and it's still saying 32 PSI... You might have a faulty sensor
99C5Vert's Avatar
99C5Vert
most of the time, you'll get a message saying it can't read one of the wheels... at least that's what I remember.
Old Dec 2, 2005 | 10:57 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
It's just that we are using these new cover sheets for TPS reports now... Did you get the memo?
(first thing I though of when I saw the title of this post)
Old Dec 2, 2005 | 11:01 PM
scottydog's Avatar
scottydog
I had a sensor go out recently. The DIC started saying TPS maintainance required, and would give me a blank reading on the pressure.
Old Dec 2, 2005 | 11:06 PM
GrayC5's Avatar
GrayC5
Tire pressure readings of XXX or the warning message, SERVICE TIRE MON SYS in the DIC.
Following quote from the 2003 Corvette Owner's Manual:
SERVICE TIRE MON SYS (Except 206): If this message comes on, a part on the Tire Pressure Monitor (TPM) is not working properly. If you drive your vehicle while any of the four sensors are missing or inoperable, the warning will come on in approximately 10 minutes. If all four sensors are missing, the warning will come on in approximately 15 to 20 minutes. (All the sensors would be missing, for example if you put different wheels on your vehicle with out transferring the sensors.) If the warning comes on and stays on, there may be a problem with the TPM. See your dealer.
Hope this helps.
To TPS Question...
