Lighting Question
Old Dec 4, 2005 | 08:22 AM
vettman96's Avatar
vettman96
Default Lighting Question
Having read all of the threads re HID conversions, halogen upgrades and C5 headlamp performance, I have a question.
Has anyone upgraded the bulbs to offroad wattages, 9006 low beam from 55w to 80 w and 9005 hi beam from 65w to 100w?
Does this offer any improvement, and will the factory wiring harness
tolerate the additional load?
Seems to me that if the pattern of the stock reflectors is good, the
added wattage would be a good thing if nothing burns up.
Plus the expense would be less.
Old Dec 4, 2005 | 08:30 AM
DeeGee's Avatar
DeeGee
The info I have is that the stock wiring harness will not take the additional wattage.
The reason I say that is my Euro headlights came with a new harness to support the PIAA dual filament 135/95 bulbs. There are notes on the instalaltion that warn about using the higer wattage bulbs with stock wiring.
The euros have a much more defined and shaped beam. The stock lights have a wider diffuse flat beam pattern.
The harness also adapts the connectors to operate the dual filament bulbs froma single connector in the light housing.
Old Dec 4, 2005 | 08:50 AM
rws.1's Avatar
rws.1
I have 100 watt in my '88. I have been looking for a source of off road high wattage bulbs fo rmy '01.
From what I have read, the stock wiring system can handle up to 110W but not the 135 that DeeGee used.
Old Dec 4, 2005 | 08:53 AM
RAO-3's Avatar
RAO-3
Although I'm not positive there may also be some concerns about the stock lenses also being able the handle the extra heat load of the higher wattage bulbs. The Euro lenses are glass whereas the US version is a polycarbonate plastic from what I can remember.
Ray
Old Dec 4, 2005 | 09:11 AM
DeeGee's Avatar
DeeGee
Ray
The stock housings are pretty cheap and nasty in comparison
Here's the Euro
Old Dec 4, 2005 | 10:14 AM
vettman96's Avatar
vettman96
Are the euro housings and lenses heavier than "stock"? How will that affect the life of the motors?
My C4 had trbls with the heavy lamps wearing out the drive gears.
Old Dec 4, 2005 | 12:30 PM
leaftye's Avatar
leaftye
The euro housings are heavier, but it hasn't broken my motors yet, and I have T1 bars and don't slow down for broken pavement (that's what shocks are for). I bought my euro lights with the wiring kit, and I run and use 90/130w bulbs everyday, twice a day.
Old Dec 4, 2005 | 05:42 PM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Default 65 w and 100 w
I have the 65w and 100 w on the passengers side and the 9005 to 9006 mode on the drivers side. Don't waste your money on the higher wattage. Do the 9005 to 9006 mode. Big difference, could not see any difference with the higher wattage.
Clayton
To Lighting Question
