I believe all C5 verts do this and it will rub the paint off the leading edge of the toneau. However, there is enough slack in the top to prevent this if you put your hand or a rag or something between the two. It's not all that much trouble and it will prevent any finish problems or wear on the cloth.
With just a little effort, this works as described. I can't believe everybody wouldn't do it this way.
