Why do our console lids only open 45 degrees?
Old Dec 5, 2005 | 10:49 PM
hrcantrell's Avatar
hrcantrell
Default console cover
So that is where the gas button is?
Old Dec 5, 2005 | 10:55 PM
ALLEGRO's Avatar
ALLEGRO
Where can I get those chromed muffler bearings ?
Old Dec 5, 2005 | 11:13 PM
Awsum98's Avatar
Awsum98
just spray some silicone or WD-40 on the hinges and it will open fully without any effort !
Old Dec 5, 2005 | 11:27 PM
b98's Avatar
b98
Old Dec 6, 2005 | 12:01 AM
Dark Syde's Avatar
Dark Syde
Cruise-In VII Veteran
Originally Posted by Groovepusher Sly
Actually, if you're only going to pop the gas cover, you only need to open the lid a little. If you need to arrange items, or use the accessory plug, pull it all the way open.
If you think about it, you probably do the quick flip more often than anything else.
Sly
"Arrange items", you mean like 2 napkins or the small note pad that I have in there....
Old Dec 6, 2005 | 12:10 AM
edensknight's Avatar
edensknight
Originally Posted by SavPrato
What a dumbass design.
I freaking agree!
Old Dec 6, 2005 | 01:28 AM
hep's Avatar
hep
I use a "needle" type oiler filled with WD 40 to get precise lubrication of the hinges. Prevents a mess. Hep
Old Dec 6, 2005 | 01:47 AM
MrRenoman's Avatar
MrRenoman
Here are the official instructions for operating your console door. Please read them carefully.
Old Dec 6, 2005 | 02:51 AM
MrRenoman's Avatar
MrRenoman
I think these instructions are a little clearer...
Old Dec 6, 2005 | 06:46 AM
Dark-Knight's Avatar
Dark-Knight
It's a very poor design feature in a otherwise great car...
Old Dec 6, 2005 | 09:51 AM
chucks's Avatar
chucks
C3 of Year Finalist (stock) 2019
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Oldtimer
The famous Corvette double hinge will probably win an award as the pinnacle of engineering excellence.
Old Dec 6, 2005 | 10:18 AM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Originally Posted by 2k1 Vette
I seem to recall (I dont have my C5 anymore) that the emergency brake got in the way a little bit too. If you try to open it while the emergency brake is engaged then that might be a little bit of the problem.
I thought this as well since I can never open mine 90 degrees when the emer. brake is engaged.
-Mike
Old Dec 6, 2005 | 01:06 PM
  #33
Cirrus8's Avatar
Cirrus8
As has been said before, OIL THE DAMN HINGES and it will open every time very easily!!! It is not a double hinge or a two stage design. It is a single over centr hinge and if You wil just OIL it, it will work as designed without pushing, pulling, or using both hands. Let me say it one more time ---- OIL THE DAMN HINGES.
Old Dec 6, 2005 | 01:10 PM
  #34
Hammie's Avatar
Hammie
Thanks sir. However I believe we got it the first time, but if any of us didn't, we sure did now.
Old Dec 6, 2005 | 01:48 PM
  #35
BUK VETT's Avatar
BUK VETT
Hey - maybe that's why when I open mine past 45 degrees it takes a ton of effort and makes a sound like an old bank vault door being opened??? metal on metal kind of. . . . ???? Some type of creaking sound.
Old Dec 6, 2005 | 01:52 PM
  #36
Hammie's Avatar
Hammie
That OR, as others have illuded to, it's Chevrolet's ingenious design to install a console that evolves into a bank vault to protect your belongings, exactly how hey intended it to work.
Or just stick with the logical plan that it just needs some oil....
Old Dec 6, 2005 | 01:56 PM
  #37
BUK VETT's Avatar
BUK VETT
Yeah . . . I like that . . . it evolves into a bank vault, to protect all the valuables we keep in there. Like Bonsai said -
Originally Posted by Bonsai
"you mean like 2 napkins or the small note pad that I have in there....
To Why do our console lids only open 45 degrees?
Old Dec 6, 2005 | 02:26 PM
  #38
VinnieR's Avatar
VinnieR
From: Austin, Texas 2005 National Champs in Football and Baseball.
Next time you are doing you weekly hinge oiling, take time to look at the mechanism. The hinge mechanism is, in fact, double action. The lid cover is hinged to a bracket which moves up as you open the cover beyond the approximately 45 degree point and back down as you close the lid.
Old Dec 6, 2005 | 02:33 PM
  #39
wolfmd's Avatar
wolfmd
Originally Posted by EZEDDIE
If you are sitting in the driver seat, open it 45%, then pull it towards you at the same time you pull up on it. The lifting motion is more of a 'towards you then up' as apposed to a direct 'up'.
Hope this makes sense.
Old Dec 6, 2005 | 02:43 PM
  #40
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
wow, #40 post on how to open the console
