Wheelskin steering wheel covers
Old Dec 8, 2005 | 04:55 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
When you install a Wheelskin cover ... do you put it on over the old leather cover, or do you remove the existing one?
Don't need one for the Vette, but the cover in my Mazda truck is in BAD need of replacing. The previous owner was rough on it!
Old Dec 8, 2005 | 05:14 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Originally Posted by jedicowboy
It is a big needle. There are pre-punched holes but you do need the needle to get through them. You are probably referring to the old plastic like covers with the weird flat plastic string? These have a wax like coated string that is threaded through with a needle. The wax type substance on there prevents the string from loosening while you are going through the next hole. The instructions are very good. Also, if you go to Wheelskins.com you can order samples and see how the different colors look in your ride.
Yes it was the older type.Since you got yours from mid america does the big needle come with the wheelskin then?
Old Dec 8, 2005 | 05:19 PM
JTJ's Avatar
JTJ
St. Jude Donor '08-'09
I put a Wheelskin cover on my Buick wheel and will put one on the Vette this Spring....very satisfied. Bought it at PFYC..
It's been on for over 2 years.
Old Dec 8, 2005 | 05:46 PM
The cover looks very good - certainly an alternative to the more expensive steering wheel replacement.
Old Dec 8, 2005 | 07:33 PM
jedicowboy's Avatar
jedicowboy
Instructions, needle and string all included
Old Dec 8, 2005 | 07:39 PM
charlene's Avatar
charlene
Thank you very much for the information.charlene
Old Dec 8, 2005 | 07:46 PM
charlene's Avatar
charlene
Thank you very much for the information.....Charlene
Old Dec 8, 2005 | 08:40 PM
LS9's Avatar
LS9
I'm not impressed with the areas around the spokes. It looks unfinished . I'm wondering if there is a better way ?
