Insulated Shift Boot???
Old Dec 8, 2005 | 08:04 PM
C54FUN's Avatar
C54FUN
St. Jude Donor '03-'05-'06-'08-'10
Default Insulated Shift Boot...Anybody Make One???
Guys, does anyone make a insulated shift boot for our cars? If someone does, I would think they could sell a ton of them on this forum. Appreciate the help and thanks.
Joe
Old Dec 9, 2005 | 09:13 AM
C54FUN's Avatar
C54FUN
Anyone????
Old Dec 9, 2005 | 09:35 AM
sdef's Avatar
sdef
St. Jude Donor '10
Default ?
why would anyone need an insulated shift boot?
Old Dec 9, 2005 | 09:46 AM
2004SpiralGrey's Avatar
2004SpiralGrey
Old Dec 9, 2005 | 10:11 AM
C6~Missle's Avatar
C6~Missle
Under the shift boot is a thick rubber piece that covers the hole in the shifter area. An insulated boot won't do much to help...
Old Dec 9, 2005 | 10:21 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
It's winter time...some brave fools drive their 'Vettes in the winter, and they want to keep the heat in!
Old Dec 9, 2005 | 11:08 AM
C54FUN's Avatar
C54FUN
Guys, I am actually looking to diminsh the noise coming from my shifter, hence, the insulated shifter boot. Anybody with an aftermarket shifter knows about noise transfer. Mine is actuallly in storage for the winter.
Joe
Old Dec 9, 2005 | 12:38 PM
sdef's Avatar
sdef
St. Jude Donor '10
Default .
ok, that makes sense. you could make one yourself using the carpet insulation they use on various cars. have it sewn or glued to the inside of the shifter boot.
I assume you have already insulated everything else under the console and the carpet.
Old Dec 9, 2005 | 12:39 PM
Sorry, haven't seen any insulated shift boots for sale. I guess you could take the stock one off and try attaching some material to it.
Old Dec 9, 2005 | 04:32 PM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
If you're running a Hurst shifter, I cut a piece of new heater hose 3/4" X 3" long, (remove **** and boot) slide it down onto the shifter shaft (dry) under the **** and reinstall parts, my noise went away (installed three years ago) I checked it last month, hose section hasn't moved.
Old Dec 9, 2005 | 05:38 PM
edensknight's Avatar
edensknight
There are a number of ways to attack this situation, via simple DIY methods. And, here are just a few: Rubber insulation; Splitting a tennis ball; and, simply slipping your new custom leather shift boot OVER the orginal. The last method is what I personally prefer to use with my Hurst Short Throw Shifter. The install is clean and easy, no fuss, no mess, no cutting, and, no modifying necessary. Simply, squeeze the plastic retainer ring that is attached to the o.e. letaher shift boot, and, slip the new one over it. Pull and adjust to properly center and place the new shift boot in place. Good luck to you.
To Insulated Shift Boot???
