Anyone wanna share the "exact" instructions on how to use it, and what exactly it does..... Looks like a nice gadget to me
Pretty simple. Hook it up to your battery terminals, and plug it in to a regular 110 outlet. You can use it with the battery in the car or out of the car. I leave my battery in the car, and set the tender on a block on the garage floor beside the Vette.
The tender monitors the strength of the battery and gives it some juice when it needs it. It also has a light which changes to red when it is charging, green when everything is charged.
I only use mine when the Vette's in hibernation for the winter.
For those considering purchasing one, if you don't want to connect directly to the battery terminals, there is an optional connection cord you can purchase allowing you to connect through the cigarette lighter. I started using mine that way last winter and it works great.
Battery Float charger from Harbor Freight..... under $10.
It does exactly the same thing as the expensive ones above....
The micro chip adjusts the charge rate to match the actual drain...
You can pay a lot more but not get any better IMHO
I've heard only the original "Battery Tender" brand is good, and some of the cheapies have been known to explode.
BTW Are they really neccessary? When I had my C4, I had it parked outside, and if I started it up evry 2-3 weeks during the winter, it started right up, and no problems, voltage good. Just asking...
If you leave them hooked to 110 AC all the time, how do you close the hood, or do you leave it unlocked ? Personally, I don't feel comfortable having a AC wire connected to my car ALL the time for 6 months. But thanks for the info..
There is enough room to fit the battery terminal clamps on the posts without the hood hitting the clamps when the hood is closed. Also, I put the battery tender cord at the back of the hood by the windshield and closed the hood. There is enough room there for the cord with the hood closed. I looked at the Battery Tender light after I closed the hood and it showed green so I think I still have a good connection
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I open my hood cover the whole car with a car cover and the open hood with sheets and my engine bay with sheets but i leave the battery area uncovered i plug in the battery tender plus and that's it don't worry about leaving the wires connected for 6 months most of the forum members do this and their is no problems unless your car is stored outside is your car outside for the whole winter?
My car's stored in the garage, with a car cover over it. This is the first year I've had it, and the first time I'll be storing it. That's why I was asking such questions. First of all I don't like cords hanging in and out of the car like that. Even if there's space to stick the entire Tender under the hood, I just don't like the idea of having the car HOOKED up to AC (constantly) for next 6 months. I wonder if there's another way of doing this. I'd like to keep the battery in working order, but not keep it plugged to AC constantly. Normally, I'd disconnect the Negative (Black) wire from the battery when storing. But I'm afraid that in "this" case, I might get computer error codes, or lock my stereo. I'm open to hearing suggestions....
I just bought a Battery Tender Plus - nice unit and comes with a 10 year guarantee. It replaced a Sears Diehard battery maintainer that went out in less than 2 years.
You have to hook it up to something to keep all the computers in the car going and a batter tender plus is great.I put my battery tender on the top of a stepstool about two feet from the car the car is clean and so are the battery cables so their is no problem with any dirt or scratches on the car.Keeping it hooked up for 6 months does no harm i have an 03 and i have done this for the last two years and alot of people on the forum have also done this just ask them they will tell you
